help needed
GT3 player par excellence
help needed
on the road
can someone chk what’s fuel tank capacity of rs4.0
thx
thx
follow up
when fuel light comes on how much fuel should be left still?
67L unless you spec'd the 90L option (available only with LHD)
In my 3.8 the light comes on with about 15 to bone dry.
What's going on?
i 'll have dealer recalibrate
when ligth comes on, i can at 12.5gal at most, and yes i have tried to invert the pump handle, if not, then only 11.5 gal
i think the reserve when light comes on is approx 3 gal
3+12.5 = 15.5. it appears that my calibration is just a tad off
and 17 gal is too small!
i can't get more than 200 miles ;-(
^ u must have heavier foot than i
I remember seeing this problem with porsches
https://rennlist.com/forums/showpost...0&postcount=16
try this
try this
^ my seem a little different.
gauge shows enpty
light comes on
put gas in, including inverting the pump
the gas pump will stop around 12.x gallons and fuel will come back out of filler neck if i keep pumping
at this point the gauge will read FULL
so:
when light ocmes on i shoud have about 3 gal reserve
i can only pump in 12, so that means there "should be" 15 gallon in the tank now.
but the tank is 17.7gal?!?!
yes pissedpuppy , i bought a CGT
gauge shows enpty
light comes on
so:
