remove gear box from engine
This is my first time doing a clutch on a 2007 GT3. I am attempting to do this without removing the engine, just the gear box. Everything is disconnected but I am having a hard time trying to pry the gearbox away from the engine. It is only about 1/4 inch separated.
The triangle bracket at the top of the gearbox has been removed.
Is there a requirement to separate the throw out bearing ?
Or just a matter of prying harder?
did you remove the clutch fork rod from inside the bellhousing? its accesed from the vent tube on the d/s of the trans. remove the vent tube remove the 10mm bolt and bracket remove the black plug and then screw a 6mm bolt into the cap of the fork rod and pull it out
Thanks. It is like the old G50 transmission on 1989 Carrera then. I will get to that.
Sounds like a smart move to me. According to the previous owner of my car, the dealer dropped the gear box to replace the leaking RMS.
On other vehicles, I have removed engines and sometimes a transmission. It was always much easier to keep the engine in place. Don't need to mess with coolant, oil lines, electronics and other systems not associated with the transmission.
Is there a reason why we hear so often about dropping the engine for clutch work and replacing the RMS?
I'm not sure you hear much about dropping engine for clutch work and RMS. Usually what you see is dropping engine for other work and doing clutch and RMS while in there.
Dropping the engine sucks and is not inexpensive, so while doing it it's proactive maintenance time.
Have gone through multiple clutches but rarely dropped the engine because of. Even RMS can be repaired with engine in place let alone just a clutch job...
cbracerx (05-30-2023)
Well the gear box is down and out now. I can see that the cross shaft will be real fun on the way back in. I have done G50 mating on the ground but never in a car. Please pass along any tricks to make this easier. I am planning on taping the fork to the engine side and mating the gear box to that, then somehow lining up the holes for the cross shaft to come in. All with mirrors.
You know, next time the whole engine comes out. I already have had to drain the coolant and the oil so what is left?
The Rebel
Disconnect Fuel lines, Air Con lines, wiring harnesses, oil lines, coolant lines (don't forget the short one by the coolant reservoir), power steering lines, motor mounts, remove the airbox, and maybe I forgot something because this is all from memory. We do this two-three times per week. In fact today we were reinstalling one of our 4.15L Mezger engines.
Anyone feel free to PM or email me if you have any questions or if you're stuck with anything. MJ@mckengineering.us
yelcab i sent you my cell feel free to call. i have some tips that will make your life much easier reinstalling the trans. i can have mine in the car in about 1 to 1.5 hr ready to fire
The Rebel
