Cloud of smoke cold start
It's a daily driver [now] and have cold started it maybe a hundred times since with no such issue. I'm wondering if anyone else has experience with this. Things to watch for, worry about...
Thanks for any input,
Z.S.
Mine went bad on my Cayman R at about 20k miles. Started with cloud of white smoke. Smelled sort of like oil, and at first it was just a cold start but then it would smoke as I drove down the street.
Z.S.
The techs tell me invariably when they are working on an engine and open up the intake they find the intake walls oily. The source of the oil is the hose that comes from the AOS. The AOS is just not able to remove all oil vapor from the crankcase fumes and as these fumes reach the intake and have to make a sharp turn the heavier oil vapor particles impact the intake wall opposite where the hose connects. If this happens with the engine running the oil makes its way down into the engine and burns and one is the wiser.
If the engine is shut off the intake heats up and the oil runs down and if the intake valves are open on into the cylinder. If the valves are closed the oil collects on the valves.
If the engine is started cold this oil doesn't burn completely and smoking is the result.
My experience over the years is both of my cars (2002 Boxster with over 312K miles and a 2003 Turbo with over 155K miles) will experience a hundred or more starts with no smoking between starts when there is smoking.
My usage seldom has a cold engine started and then the car put away again without the engine having been run long enough to get fully up to temperature. It is this type of usage -- short trips -- that seems to encourage cold start smoking.
Also, I have over the miles observed that as either engine gets close to being due for its 5K mile oil/filter service the engine is more likely to smoke upon cold start even though the engine was fully up to temperature when I shut it down.
About all you can do is what the techs do when the engine smokes. I covered this above and won't repeat it again here.
Furthermore, my advice is if you can avoid short trips. Longer trips get the engine up to temperature which helps reduce the possibility the engine will smoke at its next cold start but it also helps remove water from the oil and helps keep the battery topped up. The engine needs to run some time -- 10 or 15 minutes or longer -- in order for the battery to be topped up.
Avoid overfilling the engine with oil.
And last but not least don't run the oil too long. As the oil accumulates miles it gets contaminated with unburned fuel and water and other combustion byproducts. These all work to increase the tendency of the oil to foam and create more oil vapor which overloads an already overloaded AOS.
PS. I also thought it was the AOS the first time it happened and took it to Porsche who couldn't find anything.
I do occasionally give my 911 an Italian tune up.
That could be the culprit, leaving a bit of oil.Cheers,
Z.S.
This has been fairly consistent since "new" to me (5 years ago with less than 6000 miles currently at 32,000 miles).
This oil changed I asked them to fill one marker low. They complied and I have not had a smokey startup since the Spring oil change. Time will tell.
1/ once when it was cold and after I moved it a car length and then started it again after a few minutes. It was as @jhbrennan mentioned but it only lasted a <5 seconds. I did shut it off, briefly inspected the engine and re-started it and all was well.
2/ two times when it was relatively warm and the car was parked on a side-to-side angle (one bank higher/lower than the other). Just a puff of white smoke out of the tail pipe on the lowest side of the vehicle (as per Wayne Smith...FWIW, I've never seen Wayne's 997 do that...and he has confirmed that his flat-6 is a smoke free engine!)
