Porsche 911 Twin Turbo Carrera
why is there white smoke coming out of my 911 twin turbo porsche??? Could it be that I lent it to my friend who hadn't driven a stick in a while and he did something to the engine??
Does it go away pretty quickly after startup? A quirk of the 07-09 Turbo engine is that if you run it hot and hard and shut it off without a bit of a cool down, there can be some puffs of white smoke at startup. The solution is typically to let it idle for ~20-30 seconds before turning it off.
dak996 (01-24-2023)
Does the smoke smell like burning coolant (sweet maple syrup type smell) or like oil? If coolant, that could be a leaking head gasket. Oil smoke, because of the flat 6 configuration, oil can leak into the cylinders and some smoke can emanate upon initial start-up but should then go away.
