2005 PCM Navigation Problem
Hi Guys, my cursor/origin point is stuck in a Radom location, does any one have an idea how to remove/restore, please? I have tried restoring factory settings. Thanks
Did you recently have a windshield replacement, or any work done that would have affected the area under the plastic cowling under the passenger side wiper?
Like mrhebert says, there have been many cases of the GPS antenna sitting under that cowling getting unplugged and not plugged back in.
Ha. Same problem after replacing wipers. Hardly ever use the factory NAV. I figured it had to be reset and I would check later. I had already forgotten about it until I read this post.
