What's this noise?
Old 05-18-2017, 05:26 PM
JCGMS
JCGMS's Avatar
Default What's this noise?
Ok peanut gallery.....
2006 997.1. 95K miles, no issues, diligently maintained. Presumably larger bearing given build date / VIN / Engine #. Water pump replaced 40K miles ago. No leaks.
Got in car (to go to dentist of all places) and heard this rattle. Seems to be coming from drivers side of engine bay. Increases in speed with RPM. Gonna flatbed to Indy tomorrow. Ideas?
Old 05-18-2017, 06:01 PM
Buddhamonk
Buddhamonk's Avatar
is it rev dependent?
Old 05-18-2017, 06:27 PM
JCGMS
JCGMS's Avatar
Yup
Old 05-18-2017, 06:37 PM
semicycler
semicycler's Avatar
Remove the serpentine belt. Rotate all the pulleys to see if any are loose or noisy. Start the engine briefly with the belt off and see if the noise returns. This test will isolate the noise to one of the accessories driven by the belt or to the engine itself.
Old 05-18-2017, 08:03 PM
JCGMS
JCGMS's Avatar
Thanks. Definitely a logical way to go about it. My DIY doesn't really extend past oil and brakes/rotors and the car is in the parking lot at work. However if I had the time and it was at home would definitely try that route.
Waiting for flatbed to tow to indy, not gonna take any chances. I'm thinking it's gonna be the water pump.
Old 05-18-2017, 11:57 PM
OKB
OKB's Avatar
bearing or clutch in alt or comp or some pump
Old 05-22-2017, 03:33 PM
JCGMS
JCGMS's Avatar
It was the water pump. Bearing loose. Impeller intact. They also replaced the tensioner and idler pulleys. Not a pretty bill.
I'm now on my fourth water pump. 1st one failed (leak) at 57K miles. Second one started leaking a week after installation and was replaced right away. #3 (this one) lasted just shy of 40K miles. I don't know if play in the other pulleys exacerbated the failure.
Old 05-22-2017, 03:45 PM
semicycler
semicycler's Avatar
Honestly that's good news. My first instinct was a bank two cylinder issue with the noise coming out the driver's side exhaust. That would have been an expensive engine repair!
Old 05-22-2017, 06:29 PM
JCGMS
JCGMS's Avatar
Yup, at least it's something I knew would need replacing at some point in the next few years.
Old 05-23-2017, 11:15 AM
German888
German888's Avatar
Maybe rethink the brand of water pump your purchasing...
Old 05-23-2017, 12:08 PM
JCGMS
JCGMS's Avatar
They've all been OEM. What are the alternatives?
Old 05-23-2017, 12:09 PM
Petza914
Petza914's Avatar
Received 6,596 Likes on 4,194 Posts
4 water pumps in 100k miles is an impressive record - like double the norm. Hoping this one sees you through for the next 40k-50k miles. Did you verify that they installed one with a plastic impeller and not a metal one?
Old 05-23-2017, 12:17 PM
JCGMS
JCGMS's Avatar
If you ignore the second one, which only lasted a week, that's 2 pumps lasting 95K miles and 11 years of service, so I think maybe par for the course. The pumps have all been OEM so plastic.
Old 05-23-2017, 12:20 PM
Petza914
Petza914's Avatar
Yes, that's true, and you're right 40-45k miles is what I consider the PM service interval on them.
Old 05-23-2017, 07:05 PM
Lvt19672
Lvt19672's Avatar
Is it a 3.6 or 3.8?
Quick Reply: What's this noise?
