Full or Empty gas tamk?
In a couple weeks I'll be putting my 911 in the garage for the winter with only a monthly 30 minute gaunt to keep things lubed and running right. Should I store the car with a full tank of gas or keep in near empty. Not so much concerned about gas going bad as much as possible condensation in the tank.
Received 5,402 Likes
Full-full.
1 ounce of StaBil per 2.5 gallons fuel.
And don't start the car till spring, when you intend to begin use again.
OK. I thought I read here MANY times that I should take the car out maybe once a month and bring it up to temp, maybe run it out about 15-20 miles down the highway after a nice warm-up? No?
Originally Posted by 911Finally
No?
This circulates the oil and wets the seals and o-rings and such with fresh oil which helps keep them from drying out and shrinking from lack of use.
If it is not too cold run the A/C to circulate the compressor oil and refrigerant to help keep the A/C system seals from drying out. Be sure to run the cabin vent fan a while after turning off the A/C compressor to remove any moisture that might have condensed on the car's air ducts.
Store the car with the tank full or close to it. This keeps all the in-tank hoses and such submerged which helps keep them from possibly drying out and becoming brittle.
The tank doesn't "breathe" as it is a sealed system.
Be sure you change the oil and filter before putting the car away.
If you're not on battery charger, you must run long enough to put the charge back that was expended for the start.
I'm in the same situation with storing the car soon. But I do not start it unless I can drive it for a bit, and then at least weekly. Starting an engine with dry cylinder walls is something I want to do as infrequently as possible.
As you have already seen you are going to get diametrically opposed opinions on this. Here's mine:
1. If the objective of storing the car is to prevent getting salt etc on/under the car then you should not take it out at all. The people who say "i only take it out on dry days" are kidding themselves as salt is on the road and it will get on the car. If you are going to drive it occasionally then may as well drive it every day
2. The car seals etc will not dry out and get destroyed in a couple of months. Fill it up with gas, put on the tender and leave it. If you cant bear that because you think the car will not survive, see #1
Cheers
Cheers
I agree that driving in NJ on dry roads only infuses salt dust into the underside of the car. Don't do it. I'm in Upstate NY and the 993 and 997 do not see pavement till after the March or April heavy rains wash the roads clean. I bike ride all winter outside and come back from a ride coated n talcum powder salt dust and can taste the salt in my mouth. Follow Vern's advice.
When you fill it up for storage, do it with non-ethanol enhanced fuel as the alcohol absorbs water and will be counterproductive to what you're trying to accomplish by filling the tank.
I would put it on jack stands. On a metal tank, its customary to fill it will fuel and stabilizer. But I think the 997 tank is not metal so that takes out the internal tank corrosion issue but not the chance of humidity forming inside an empty tank.
At the very least, keep it on a tender and start it once a month up to operating temps, run all systems (heat, AC, windows-sunroof up/down, blinkers, stereo, headlights, powered heated seats etc.)
Dormancy is the bane of any mechanical object. I had a small collection of bikes at one time. I always started them once a month to keep things running properly. Even now I have a collectible car, but I actually drive it once a month around the compound to keep the seals wet. And even then, I start it once a week just to keep on top of anything that might be creeping up on me.
