Pdk filler plugs where?
I understand that the PDK transmission has 2 separate fluid systems: clutch and Gears.
Where are the filler plugs located for each system?
Thanks.
Regards,
cf
Thanks.
Regards,
cf
I have a schematic that shows them clearly. from my Alldata subscription. I can send pics from cell to cell. e mail phone no. to : robertschaller33@yahoo.com
Reading the manual, ATF fill is a hex head bolt on the left in front of the output shaft above the two external lines and what looks like a wire clip. I think this is the clutch oil. The manual I have references changing the final drive oil, but doesn't say anything about how to do it. Not too helpful...
the gear oil drain plug is just outside the perimeter of the transmission (plastic) pan. and the gear oil fill plug is on the same side, a few inches up on the case. both plugs are hex head and a little larger than clutch oil fill plug. clutch oil drain plug is on the tranny pan. and the fill plug is on opposite side as gear oil fill plug. I forget left from right, but can send schematic
I know where the pdk clutch fluid drain and fill is located.
