PPI / PDK Issues
#46
I'd vote for taking the deal too, I was surprised that you managed to get that much of a break. I personally don't think a lawyer will be of much use other than costing you more money. On the good note, you'll end up with a PDK that will be good for a very long time and you won't have to deal with the pricey 100,000 mile PDK service until the car has 150,000 miles (240,000km) on it.
#47
It's not really anything more than changing the gear oil, but when I got the clutch fluid changed the service advisor mentioned that the gear oil was going to be even more expensive... I don't recall for sure but he mentioned a number in the one grand range.
And I notice I got the number wrong for the mileage. It is 12 years/120,000 miles for the PDK gear oil change for mere 911's. If you have a GT3, it is 96k miles and clutch oil every 6 years/48k miles.
#48
#49
How often are you having the gear oil changed?
I'm at 38k on a 2011 GTS.. thinking I'll have the gear oil/clutch fluid done in the next couple thousand miles.
#50
I have the Guard Transmission LSD installed in mine and Matt from Guard recommends it be changed every 4 - 6 track days. He and John at BGB also recommend running a tranny fluid pump / cooler setup when using that diff so I have BGB's installed on mine. There is a cockpit mounted switch for the pump and I only run it while on track and when cooling everything down after coming off track.
#51
So I gave the dealership the green light to order the new transmission. I will have some more updates about my situation in the near future. I don't want to spill the beans before anything is confirmed. I was wondering if there is anything I should have them do while the transmission is out. I know for my 986 Boxster it was a good idea to have them replace the RMS. That solved a minor oil leak I was having. It only cost me $20 in parts and no labor. Is there anything recommended for my 997.2 while everything is apart?
#52
spark plugs - replace should be cheap
serpentine belt
that pretty much knocks all maintenance out for awhile.
![bigbye](https://rennlist.com/forums/graemlins/xyxwave.gif)
#53
Note that I'm not personally recommending these...but to help with your question I'm just recommending you look for threads about these and see what you think:
I've seen some threads where people recommend changing the water pump sometime around 50k miles (which is right about 80k kilometers coincidentally). Also, the AOS (air-oil-separator) gets mentioned at times in higher mileage cars.
#54
I haven't heard of water pump replacements in the DFI motor ... yet.
#55
Ah... thanks for the catch Wayne. I blurred the .1 and .2 motors in my head. Maybe the same for AOS? A good search of the forum for those should make it clear.
#56
Alright for all of those who were curious I had my transmission replaced and got my car back yesterday. it took about a week and half. I did ended up accepting the 50/50. I didn't let the original dealership that did the PPI do the tranny swap. I ended up taking it to the other dealership that diagnosed the failed tranny. I tried to have them fight further with Porsche Canada to see if I could get a better percentage. They couldn't. I felt like there was a conflict of interest with the first dealership since they wouldn't just say they screwed up the PPI. The grand total bill was $6629 CAD. I feel that's not bad. Porsche refurbished transmission with 2 year warranty. I'm thinking I'm might sell my 09 in the summer after it comes out of storage. I would get a decent price I think with this warranty and maybe starting looking at 2012+ ones.
thanks to all for your input.
#58
Wow that was really nice of Porsche Canada to step up on a used car that's almost 10 years old and not purchased at a Porsche dealership.
If you are going to look at selling it and getting a 991. With all the money you put into this vehicle...I suggest getting a cpo on the next one
#59
#60
Yeah, in addition to a 1960s manual transmission, try getting a starting handle and acetylene lamps with a man with a red flag to walk in front of you. You don't want any modern technology.......
