Rear Engine Compartment Lid
I really have to slam my lid to lock it into place. I've tried to lower it gently then push but it doesn't lock. Is this normal on a 997.2? I just did air filters last week and have meant to post before. Hope I'm not hurting anything. Thanks in advance for any advice. Cheers!
Should not need to slam - you should be able to lower it, then gently but firmly press down to latch it. Maybe the latch needs some lubrication?
you can adjust the height of the locking mechanism. Just loosen the two bolts on either side (on the aft part of the engine bay) and move up a bit. What is essentially happening in your case is that the bump stops need to be compressed a bit before the locking mechanism engages. Moving the mechanism up will make sure it locks before the bump stops are too compressed.
Realize this MAY also raise the height your deck lid will sit when it's locked. But that might not be the case if the mechanism has slid lower over time.
Or is it just mechanical, I have had vettes with both, the C6 was self closing and the C7 went back to mechanical. The reason for the question is that some cars with electric releases also have electric lock down.
Just reach around the whole air box, grab it, and try to move it around. If you can, it is not seated. The box has pins that are seated into rubber gromet-like things that then sit into rather large holes in the chassis. The box is not bolted in on a 997.2.
If you did unseat the box, you really should remove the whole thing requiring you to remove the hose from the throttle body. The reason for removal is that these grommets can come loose when you pick up the box and can be sitting all crooked under there. This is not difficult, just a bit fiddly.
Peace
Bruce in Philly
Moreover, this is the same setup as the front hood release. Many people have to replace the electronic trigger that opens the front hood because they pull on it very hard like it's mechanical (because it IS mechanically linked on many other cars). It's basically an electronic button that activates a servo and it just needs a light touch to make the connection. If they realized this, there would be less broken frunk released triggers.
Thank you all for the ideas and input, I just open the engine compartment, loosened the two bolts (10mm), holding the plastic catch, pulled the unit up a bit, tightened said bolts and the lid closes just fine, just a gentle push and its locks up and releases with no issues. Again many thanks. Cheers!
you can adjust the height of the locking mechanism. Just loosen the two bolts on either side (on the aft part of the engine bay) and move up a bit. What is essentially happening in your case is that the bump stops need to be compressed a bit before the locking mechanism engages. Moving the mechanism up will make sure it locks before the bump stops are too compressed. Realize this MAY also raise the height your deck lid will sit when it's locked. But that might not be the case if the mechanism has slid lower over time.
No problemo.
