Change tail light behaviour with Durametric
I have a german sold 997.2 C2S imported to Sweden. We're required to have tail lights switch on all the time but not in Germany. The car is without rain & ambient light sensor.
So when I have my light switch to the "home" position only the front DRL's are on. Xenon lights are off and tail lights are off.
If I turn the light switch to the "on" position the DRL's stay lit, the Xenon's and the tail lights turn on.
Is there a way to reprogram with DuraMetric so that the tail lights is on in the "home" position of the light switch?
Do you have Sport Chrono - if so, have you tried using the PCM options to turn on DRL - not sure if that will just turn on the front or if it includes the rear. Good luck.
Yes I have Sport Chrono and DRL is activated, still it only turns on the front DRL.
It there a separate tail DRL, I thought there is only one tail light. Or maybe the tail LED's are just stronger in the "on" mode.
2009 C2S
I have the Durametric pro (allows for coding changes such as this) but unfortunately, the tool is poorly documented. See this thread and the link for a crowd sourced manual by floatingkiwi here:
https://rennlist.com/forums/997-foru...ns-manual.html
From screwing around with my Durametric, there are all kinds of coding possible for different regions of the world sometimes showing specific countries like Dubai. I would assume, that lighting behavior is one of the characteristics of region/country coding but I am just not sure. Unfortunately, the tool is expensive for the Pro, coding version so you may just want to go to a dealer and have them code the car for you. Or, contact your local Porsche club chapter and find someone there with a Durametric. The Porsche guys are usually very helpful with this stuff.
Peace
Bruce in Philly
Peace
Bruce in Philly
I haven't played with the daytime driving light settings in Durametric myself. But digging around I see a few options, mostly for the front.
Front Module Coding:
Daytime Driving Light Adjustment (Active/Inactive)
Daytime Driving Lights Activated via PCM (Yes/No)
Mandatory Daytime Driving Lights? (Yes/No)
Rear Module Coding:
Tail Lights (Blanked out - no options available) - could be because the car from the USA?
So it looks like the fronts can be coded but the rear can not. Maybe call your dealer and ask them what's possible with PIWIS? I seriously doubt there are hardware differences between the German and Swedish car models - it has to be a programming difference.
Rear Module Coding:
Team Owner
The guy I recently bought my 997.2 from was a software engineer down in Austin. So, he was very good with his Durametric. Two changes he made I like:
Front side markers are also turn signals now.
You can start the engine without foot on the brake with PDK.
So, I bet the right guy could do this for you.
OK - As far as I know there is no separate PCM option to turn on rear. Back to my original suggestion - tell your OPC you want DRL to include all lights on. I had this done on a 997.1 turbo and only lights that didn't come on with DRL were the instrument lights. I believe they used their proprietary PIWIS to program this.
Headlights, front parking lights for DRL and tail lights turned-on are standard in Canadian 997.1 so it can be done. The only lights that do not come on with DRL are the instrument and the side-markers...
I talked to my local Porsche dealer, they told me they can only program it so the low beam is automatically started when I start the car. What I have seen on Swedish sold cars is when the light switch is in the home position these lights are turned on: LED DRL front + tail lights. This is what is required in Sweden during daytime driving.
It sounds on my Porsche dealer that if they to the reprogramming I will get: LED DLR's, low beam and taillights in the home position.
What I want is only LED DLR's in front and tail lights.
I also don't think there are any hardware differences between the Swedish and German cars, it must be software.
As I noted above, there is coding exposed by the Durametric that shows country and region specific items..... this is different from specifically coding daylight running lights. As I noted, I don;t know if these settings affect the lights, but I still am willing to bet the dealer does not fully understand the complexity of these systems. Try another source in Europe.
Peace
Bruce in Philly
Yes I'll have to find a Swedish Durametric guru who can help :-)
To clarify, in "home" the front position lights and the LED DLR "stripe" is on.
When I turn the light switch to the right 2 steps to turn on the low beam, the position lights turn off and the LED "stripe" stays turned on. The low bean is also turned on of course, and the tail lights.
And what I've seen is on other swedish cars is the position lights, LED stripe and tail lights being on at the same time.
Someone posted a headlight switch MOD that puts a jumper between 2 of the switch terminals on order to turn the fog light LEDs on as DRLs with the switch in the Home position. . I believe because of the way it's jumpered it also turns on the taillights.
that option is blanked out on the older modules, until the 2008/2009+ modules were manufactured to accommodate the 2009+ rear led taillights. the newer modules allows the user to change from 'incandescent' to 'led'; i believe they are voltage settings.
So you'r saying that on cars from 2009 there is a setting to change for the tail light?
Yesterday I compared with a friends Swedish sold 997.2 from 2009. In home his car lights ut the front position light and LED stripe, and the tail lights.
If I can find someone with Durematric that can help me in sweden we can compare our cars's settings.
The 997.1 fog light hack will not work, the fog light is controlled by a wire in the light switch, but there is no separate wire to control the tail light. When you switch the light switch to turn on the lowbeam itäs just controlled by 1 wire in the light switch. So there must be something else down the line that controls what lights are lit when you turn the light switch to enable low beam.
