Spark Plugs Easy-Flange Studs PIA
All
Yesterday, undertook Spark Plug replace at 30,000 miles on my 09 C2S. Read everything posted here and really not a complicated job. Everything but the flange stud nuts on the exhaust manifold/cats. I soaked the hell out of the studs and nuts with PBB in hopes they would back off dispite obvious rust. Well, gentle readers, didn't happen for your sad writer. Broke one off after another.
Ok, no problem, I will just pop them out with a C Clamp. Nope, no luck. Next I will just drill those nasty bastards out. Nope. Now I'm stuck. Today, I'm going to try to heat them up and bang them out. Another problem is that I can't get the O2 sensors out and I don't want to muscle them and break them too. So now I'm trying to get these bastards out with the cats still attached.
I sort of feel like the Knight of the Sad Countenance battling the windmill of flange nuts. Any other ideas would be much welcomed. Oh yea, spent about 8 hours on these studs and broke/wore out many a drill bit.
2009 C2S 100K miles - two DIY plug changes so far
I know it is after the fact, but you didn't have to remove those three evil bolts or O2 sensors...... scroll down to my post here:
https://rennlist.com/forums/997-foru...lug-diy-4.html
However, I broke those bolts myself when I did my Sharkwerks cross pipe.... If you broke them and the nut came off, they just punch out.... really easy with a punch and hammer. If the nut is still there, you can use a grinder or other medieval way.
I highly recommend you remove the rear bumper if you have not already done so. It is easy to do, and makes life way easier.
Peace
Bruce in Philly
Peace
Bruce in Philly
I just replaced my plugs and coils - removed everything but the cats and it was a breeze, though maybe it's different on a .2
However I also wanted to swap my water pump (which requires cat removal) and aborted the project after seeing those same bolts. I am now formulating a plan to proceed. Heat can't be applied there because the inside nut is awfully close to the engine and some plastic/rubber parts there (again a 997.1).
Ah the fun of DIY maintentance...
Thanks all. I had to take a break this morning from the studs. Currently sitting on the beach contemplating removing those evil things. Going to heat the and try to punch them out later as mentioned. Is stainless bolt replacement ok or I read somewhere they should be zinc coated? M8 bolts I assume. BTW, the spark plug replacement was a breeze.
Going to get started again this morning. First I will try to heat and punch them out. If no luck I will dremmel and drill till the cows come home.
By the way, torque values: 7.5 for coil pack screw, 22 on the flange bolts, 18 on the exhaust header bolts, 22 on the spark plugs? Does that sound correct?
Ok so I finished the passenger side plugs and took Bruce's advice and removed the bumper before moving to the other side. Well, now I can't remove the muffler clamp sleeve nut to remove the muffler. I, of course, rounded the nut.
Is this clam bolt also spot welded or pressed into the clamp or if I cut the nut off will the bolt slide out? Having trouble getting my grinder in a position to grind the nut. Also, do I only have to loosen the outer clamp?
