Paint chips from stones...
Old Aug 17, 2016 | 01:37 PM
yvesvidal's Avatar
yvesvidal
I have my front bumper and hood lid repainted, when it looks like the surface of the Moon.
Yves
Old Aug 17, 2016 | 04:11 PM
TheMystro's Avatar
TheMystro
x2
Originally Posted by Dennis C
I've used Dr. Color chip in the past. It works well and it helps you avoid the big paint blob that you often get with touch up paint.
Old Aug 18, 2016 | 11:09 PM
patriot993's Avatar
patriot993
Bruce, LexVan, and others....could you post a pic of what your chip touch ups look like? Everytime I have tried it looks horrible, basically a raised paint area. I am probably using too much paint and poor technique...would love to see what is possible if done correctly.
thanks!
Old Aug 18, 2016 | 11:16 PM
dgjks6's Avatar
dgjks6
+1 on the Dr. Colorchip. Takes practice. It also does not "fill" in the hole as much as stain the metal black so you can't see it from some angles. And multiple layers does make it look better. From a couple feet you can't see it, but when you wash/wax you will notice.
Old Aug 19, 2016 | 12:22 AM
kellen's Avatar
kellen
What's the cost for a hood respray in a non rare (basalt black) color? Don't care about the chips now but if I do respray may consider a hood wrap. But with a full front wrap ~$2000, it may be cheaper to repaint every couple of years.
Old Aug 19, 2016 | 12:31 AM
Marine Blue's Avatar
Marine Blue
Originally Posted by Racetwin2
I read here on the forum that the best way to fix small ones is by a toothpick or even a needle. After clening and drying the spot they just used a tooth pick or needle and dipped it in the paint and then put it in the hole. If you use the paint brush that follows with the touch up paints they are usually much too big and you just create a big puddle of paint that overfill the hole in the clear coat.
I haven't tried it but seems logic and a good way of fixing the small ones. Maybe up to 2 mm in diameter.
I use a toothpick as noted and after several layers I smooth over the touched up area with Langka.
Old Aug 19, 2016 | 12:43 AM
captainbaker's Avatar
captainbaker
Dr. Color Chip on previous cars. No chips on the current ones. Gonna get a clear 3M bra for the 997. Well worth the $800.
Old Aug 19, 2016 | 12:31 PM
Devil Boy's Avatar
Devil Boy
At 114K miles, I just call it patina
Old Aug 19, 2016 | 12:56 PM
yvesvidal's Avatar
yvesvidal
I know a painter and he charged me $400 for the bumper re-paint. That included sanding, priming, base coat and clear coat.
The lid will be about the same price. I have not done it yet.
Yves
Old Aug 19, 2016 | 01:18 PM
nwGTS's Avatar
nwGTS
I was quoted $200 for A1 black including a detail after hardening if I brought just the hood in. Which is easy to do since it's just a few bolts to remove... No washer nozzles in our hoods like other cars.
Our hoods are incredibly simple to respray. No curves or humps nor ancillary attachments like washer nozzles to tape or remove.
^^^$400 for a front bumper cover respray is a good deal IMO
