2005 vs 2008 C2s, all else being equal
I'm surprised the 05 C2S had a single row bearing. Thought they all shipped with double rows. Do some research on bore scoring. That would be my main concern. For me the 2008 would justify a $8k premium all things being equal.
I've read people say the engine sounds better on the 05 and prefer the styling but that's personal preference.
I just went to Kelley Blue Book online to see what they say. Now I know many will say they are not indicative of the real value, but MANY people rely on them as a guide, so for argument sake they say the retail value in a private party transaction for the 2005 C2S is $31,494 in VG condition. The 2008 is $38,102. I didn't get into options and such but everything being equal.... Again even if it's not accurate they price them $6600 apart. As time goes by that will narrow. One of the most important things to consider is what will a potential buyer want when you go to sell? Personally I would go with the 2008. Wait, I just bought one, a cab though just 4 weeks ago tonight. Mine only had 4235 miles though.![jumper](https://rennlist.com/forums/graemlins/jumper.gif)
Something else to consider - the registration and insurance will be cheaper on the '05. The insurance part I never understood: In an accident the windshield, front fenders and various other bits would be nearly the same cost to replace. Go figure.
When I was buying my 2010 c2s 3 months ago I also had a choice between immaculate low miles 2006 and 2010 with higher miles but was cpo. The price difference was almost 15 grand. I took 2010 and don't regret it a single bit. Besides the fact that cars from 08 and up had all kinds of kinks worked out already, it's just a newer car. No matter how you slice it 3 years is a looooong time in auto world. Like one poster said " buy the newest car you can afford"
Sir Thomas Lord of All Mets Fans
Originally Posted by Nate Tempest
If you're talking about different revisions, sure, but why would that apply to mechanically identical cars? And obviously not regardless of price...
Here....again:
Regardless, all M96 and M97 engines from 1997 through 2008 can suffer intermediate shaft bearing failures at any mileage and at any time.
For those with MY06-08 intermediate shafts that cannot have their bearings replaced, we recommend to remove the grease seal from the existing ball bearing, which allows for engine oil to lubricate the bearing, but only when doing another procedure like a clutch, flywheel, or rear main seal replacement. However, this bearing is still problematic and should be upgraded anytime the engine is apart or if replacing the intermediate shaft with a new replacement shaft.
https://www.oregonpca.org/resources/...he-full-story/
8k on a 100k car less a factor but 8k on a 40k car is a 20% price difference. That's substantial. For 20% savings and all things equal and the 05 has the correct ims solution fix would buy that car over the 08 and put that 8k into wheels and an aero kit or others mods!
With all things being otherwise equal, I think in this case a factor to consider should be how long the car is going to be kept. If you plan on seiling it within the next few years, the '08 is probably the better value-holder. if you plan on keeping the car a decade or two or three, the value difference for cars so similar in build will eventually be arbitrary.
I say that if the '05 with the upgraded IMS puts a smile on your face when you turn the key and drive it... consider how much $6-$8000 will buy you in terms of future repairs, or tires.
It's really a win-win scenario either way. but I'd probably "settle" for the '05.
Which one has more of the options and color combo that appeals to you? Have you seen detailed service histories on both cars? Which one has had more things replaced? Was the clutch done with the IMS on the '05? Which one has newer brakes and tires, i.e. will not need replacement as soon?
Those to me would be the deciding factors. You're talking about an 8 yr old car vs a 12 yr old, so age-related failures aren't going to be all that different. Either one could have bore scoring, it affects all those years. I see the replaceable IMS as a plus, but ONLY if it was done to a pristine OEM bearing. If the OEM bearing had started to shed, then all bets are off.
The $8K price difference is going to dwindle, as the '08 is depreciating faster than the '05. Personally if TRULY all else was equal, I would rather save the $8K and have it for repairs, which will likely be the same on either car.
Ya, I think I'm echoing your thinking Ben. The cars really are remarkably similar. Same options, same silver on black. Even similar black wheels. The 05 did have the clutch done along with the IMS. Both were done by the same Porsche specialty shop that I'll have do the ppi, so I can ask them about the condition of the outgoing bearing. They will also do a compression test and a borescope, and check for overrev codes. (Will do that on whichever car I go for.)
The 05 will need new front brakes and rear tires soon. I'm taking that into account, but didn't mention it here to avoid confusing the main question. I've priced them though, and will use that when negotiating. Otherwise they've both had some minor work done following the dealer inspections. Most significant was a water pump on the 08 iirc. Neither has a complete maintenance history unfortunately.
If this is likely the forever car that you keep for a long long time, get the less expensive one of the two, assuming all things are equal in mileage and condition. If this is a car you plan on selling or trading in within the next 3 or 4 years, or want to have the flexibility to do so, then buy the newer car because it will be easier to sell and recoup more of the money you have put into it.
As far as "everything else being equal", I'm reminded of our training to be little league umpires with reference to the old adage - 'tie goes to the runner'. The guidance: there are no ties!
