Dead battery woes
Was away a couple weeks - returned to my car that wouldn't start....battery totally dead. 997.1 Carrera.
Managed to push it out of the garage and jump the fuse to open the hood but when I tried to jump start it...nothing. Couple sputters, sport chrono spinning and nothing.
Tow truck just left with it on a flat bed. Hopefully a new battery will be the cure to all....hope and pray that is.
Since you're here, you're open to criticism: Should have bought a new battery and dropped it in.
No need to make a simple issue complicated.
These cars do tend to eat batteries if left for weeks.
I have a cigarette lighter trickle charger that works great. I don't leave it on all the time, but if I don't use the car for more than week then I will use it
Have you already done the alternator cable fix? If not look into it. A bad cable will prevent full charging leading to premature battery failure. It's common on the 7.1 cars
Happy to wear the dunce cap here...but in my defense....
Wife was gone with the kids for the weekend in the other car and everyone I knew was at work. Couldn't get to the store and the mechanic is only 10 minutes from my house. It was the easiest and most expensive option but had my car back in a couple hours.
Back now and happy to be reunited.
If mine will be sitting for even a few days, I plug it in to the Battery Tender.
Seems like they eat more than that idle for 2 weeks. Is the 1 Ah/day value with the car locked or unlocked, as locking it is supposed to put it to sleep and lower consumption when idle, but I'd bet that almost any 997 left idle for 3 weeks won't start. From your numbers, that would be 21 Ah down from a 50-80 Ah battery, so about 25-45% of capacity. At what percentage of charge will a Battery not start a 997?
At what percentage of full capacity does a battery die? It depends on its level of sulfating. A sulfated 50% charged battery may not start. A highly sulfated battery may not start when the car sits for 2 weeks.
Sulfating occurs very quickly. Easy to check measuring the battery voltage. Anything below 12.4V (with no load) and sulfating has started. Low sulfated batteries can be recovered with pulsed current waveforms like CTek uses every time it starts:
![](https://cimg9.ibsrv.net/gimg/rennlist.com-vbulletin/875x514/screen_shot_2016_02_16_at_6_30_51_pm_6684516e37f0c2f033cb9f519b003af6738d7df1.png)
My 2010 C4S Cab is still on its original battery. It's my DD, and I average ~12k/year primarily commuting plus an occasional run up to our lake home (650 mile round trip). I've never had a problem with the electricals (it was CPO'd through April '16), but I'm wondering if I should proactively replace the battery just to avoid any potential problems...
What's the best suggestion for a replacement battery for those who have swapped theirs out?
Sir Thomas Lord of All Mets Fans
