Dead battery woes
Old 07-24-2016, 11:24 AM
North Shore 911
North Shore 911's Avatar
Cool, thanks for the suggestions ..... Any reason why you guys have not gone for the AGM batteries? There seems to generally be a $15 premium for the AGM versions of each battery at Walmart and Autozone, I'm just wondering if it's worth it (or what the benefit is)...
Old 07-24-2016, 02:46 PM
ADias
ADias's Avatar
I replaced the OEM battery with an Optima Redtop 34R. I like it due to its (most of the time) vent free characteristic. However, it has a lower capacity (50Ah) and it likes to be always topped, thus I connect a maintainer most of the time the car sits, even for 2 or 3 days. It is 10lb lighter than OEM and has a very high cranking current.
Beware that AGM batteries require charging at a higher voltage, thus needing maintainers with a 'snowflake' AGM mode, which most Cteks do.
For reference, I used the Yellow Dog Motorsports mounting base (no need for the extra cable).
Old 07-24-2016, 03:01 PM
Petza914
Petza914's Avatar
Received 6,453 Likes on 4,114 Posts
I have Optimas in both my 997s
Quick Reply: Dead battery woes
