mixing Pentosin 11S and 202
Quick question...
My steering whines a bit at low speeds (for example, when pulling into a parking space). It has been doing it for some time, didn't really bother me but finally decided to do something about it.
Checked the Power steering level...not even registering on the dip stick!
I have no idea what fluid previous owner used...I planned on using Pentosin 11S but seems like that has been superseded by 202. If I was to put in some 202 and the previous owner used 11S, would that cause a problem?
thanks!
thanks!
2009 C2S 99K MT
I have a leak in where the tank goes into the metal fitting.
Check my two threads here:
https://rennlist.com/forums/997-foru...heck-tank.html
https://rennlist.com/forums/997-foru...questions.html
As I note in the threads, there are two places to check for leaks. The first is just stick your head in over the engine with a flashlight and you can see down next to the tank. If shiny down there, you found your leak. The other place may be the steering rack itself. For this, squeeze the rack boots... if squishy, you have a leak in the rack and a new or rebuilt one is in your future. I believe you have to pull a wheel for access to the associated boot.
To replace the tank... on a 997.2, you have to remove the alternator and AC compressor.... so, I just keep Pentosin on hand. I checked lately and it definitly is leaking under the tank.... slow as all heck though. I have not had to add any in six months.... it is that slow.
Peace
Bruce in Philly
Peace
Bruce in Philly
2009 C2S 99K MT
Peace
Bruce in Philly
Peace
Bruce in Philly
CRUD! Have I screwed up?
As I mentioned in original post, power steering dip stick was bone dry when engine COLD. So I decided to put a little Pentosin 202 in at a time and then keep checking dip stick. So I put in maybe a quarter of a cup...and now when I check the level is all the way to the HOT mark. I started car and moved the wheel back and forth to see if that made a difference - nope...still too high.
What is risk if fluid too high? If too high, will I need to get a siphon or pump to take some out?
I guess good news is the whine seems to have disappeared.
***update: I should have done a search before posting...did a search and all I need to do is take a turkey baster and take out some of the excess fluid.
