oil change failure
I don't think mixing oil is smart.
Years ago... it didn't matter. Now? Stick to a brand/type and note that additive packages are very specific to certain oils, and some don't play nice.
It's the additives that do wonders for modern oils. You can, indeed, change oil types (e.g., from Mobile to Motul), unless you're going to some highly specialized type like DT40 where it'll not like much of any leftover oil, then you need to flush or follow other procedures.
But don't mix oils... because the additive packages, when in the best condition, are the defense against sludge.
You guys convinced me. Went to the store to return the wrong filter and bought another quart of Pennzoil. Got 5 quart deal with a filter of the Castro 5w40 Euro for $35 for the Audi. Now have 7 quarts that match for the Audi and 9 quarts that match for the Porsche
But I feel like I gave into Peer pressure.
Not to be an oil snob but from what I have read on BITOG the Castrol 5w-40 is absolute garbage. Both M1 and Castrol 0W-40 are excellent formulations currently and, at least in my neck of the woods, can be had from Walmart in the 5 quart jugs which makes it a no brainer. I happily use either, but, as others have noted, I will only use one or the other so the additive packages do not clash.
Also, with how cheap Mahle/Mann branded filters can be had online, and how much USA parts stores (Autozone/Advance/NAPA/etc) jack up the price on cartridge oil filters such as our cars use, combined with me being chastised on BITOG for using a WIX filter instead of a Mann/Mahle filter, I simply order online a little in advance and always have a filter on hand.
Agree and to add to this. The dealer over tightened the drain plug on my Cayenne in January and while not easily noticeable the drain plug cracked. After the service I had a nice size pool of oil on the garage and they offered to tow my car and pay for if it was their mistake. I wasn't too concerned about the money and told them I would top it off and drive it because it didn't want to wait all day for them. They said it was common for the drain plug to split when over torqued.
I don't agree with this at all. First, you have to have enough torque to compress the aluminum washer ("crush" washer). Second, you are screwing into an aluminum casting and the threads can only tolerate so much torque before they begin to fail. So, in my opinion, the torque should be "just right".
So here is what is weird, besides our obsessions: I use "standard" crush washers from Pelican with my magnetic drain plug and torque to 19 fl/lbs (per the bolt's spec). If I had my Porsche plug, I would torque to 37 ft/lbs using the exact same washer. The magnetized one never dripped and I did many many oil changes with it. BTW, that is 1.947368..... X the torque force!!! Yeeeeeowwww!!!!
WTF? We NEED to get to the bottom of this issue. How many of us are riding around with an over or undertorqued oil drain plug? I just can't bear to think about it..... the ignorance, the pain, the flaming deaths.... I have to stop now.
Peace
Bruce in Philly
Originally Posted by Bruce In Philly
This is going to be fun: How much digital ink can we spew about the minutia around a single, non-fastening bolt! I will continue......
Peace
Bruce in Philly
Peace
Bruce in Philly
Time to sell the car before my engine fails
OEM drain plug is 37 ft-lb.
Many magnetic ones are less, including the one Suncoast sells is 19 lb-ft: http://www.suncoastparts.com/product/PKMAGNETIC.html
Many of the problems with the aftermarket magnetic ones are a result of torquing to OEM specs, which is almost double the aftermarket specs. Then the aftermarket plug gets stripped when it's time for an oil change.
This does indicate that 19 pound feet should seal the crush washer.
Just so you know, I reuse my crush washers and tightened it until I felt it is right. And also, even though I did use all Pennzoil, one of the quarts I had was over a year old before Pennzoil changed to pure plus technology. it still 5w40 euro.
Motul 5w40 and new oil filter every three thousand miles for me. The aluminum crush washers are very soft and can be used more than once. 19# is just fine for the oil cap and oil pan on my 997.2. No leaks at all. BTW, the crush washers for the 6speed transmission are the same as the oil pan crush washers. Don't waste your money on a different part # for the same thing.
5 oil changes a year yields me 4 to 5K miles between changes. I buy my filters a half dozen at a time.
Interesting feedback on torque settings.
