Update on my extra oil consumption
In the year and a half that I have owned the car and put 6500 miles on it, I have had to add a total of 9.35 quarts of oil to the car. (I've kept a spreadsheet of all oil I've had to add with mileage) This excludes a full oil change after I had the car for 2700 miles.
The dealership put me on a 1000 mile consumption test and at 700 miles I had gone from 4 bars to 1 bar and then added 1 quart which took me back to 3 bars.
Dealership now has the car and has pulled the engine, which is under CPO. They did find oil seepage in cylinder 1 and compression test showed one of the cylinders not in alignment with the other 5.
Ie OP: 'I recently went to the doctor and I think I need to have a ******** removed'
Responder: 'Well I am 60 years old and can still impregnate a female just by staring at her' OK. Good to know.
Hope Porsche picks up bill for this latest misfortune $$$. If/when they do they will have owner take the oath of secrecy and we will not hear from him again. Wouldn't want the word to get out afterall
I have not had any excess smoking, though the soot still tells me it is running rich as well as burning oil.
And I drive at least 40 minutes every time. Motorways plus at least four 250 mile trips without noticing any change of levels. So there is no fuel dilution in the oil.
It requires very aggressive and hard running on every outing to avoid adding net water to the oil in these cars.
Long boring drives at 215-degree F oil temps or sub 100 C temps = making water.
But you'll pop into to tell me you drive at 200 Kph and live at 6500 RPMs and I won't believe you, because you'd burn some oil over that time, but you claim you don't... so your story won't add up.
If the engine was running rich, too rich, there would be a CEL with an error code or two to this effect.
If the engine was burning oil the oil level would probably be going down unless you were using the car for short hops in which case water accumulation would be replacing the burned oil.
Water accumulation is a real thing. Just 4K miles after I bought my 2002 Boxster I had the oil analyzed and it had 7% water. In 9+ quarts of oil that's around a 1/2 quart of water. That water then replaced that much oil that was consumed.
Might mention that while I was using my car for "short trips", 10 miles to and from work, I was also using it for longer trips of 40+ miles to 75+ miles. The problem was this was in Jan. to Mar. of 2002 in the middle of a pretty cold (normal) winter in the KC MO area. What I found after the analysis was when I monitored engine coolant temperatures in real time the engine was very cold blooded. A high speed (well, legal high speed) run down the freeway for 50+ miles never saw the coolant temperature even get to 190F.
The AOS is supposed to help keep the engine crankcase under low pressure which lowers the boiling point of water in the oil but often I believe the AOS doesn't work all that well and this exacerbates the accumulation of water in the oil.
Anyhow, relax. Your car's engine is fine. My advice is you should spend more timing looking out the windshield and less time starting at the exhaust outlets.
With respect to oil consumption though the "normal" range is so variable that anecdotal reports from other owners are next to useless.
In my opinion it would be better to just make this clear to the OP ie
" every engine is different and unless you are exceeding Porsche's definition of excessive oil consumption it is moot"
rather then bombard him with the reports of others whose cars it would seem never use any oil.
The only number that really matters after all is the definition of 'excessive oil consumption' that Porsche uses, for better or worse.
Reading the manual or doing a quick search will get you that.
So according to me - the engine in this specific car consumes no oil.
