Tires - its always something
#31
I may be a little late to this party, but here is my thread on a similar situation:
https://rennlist.com/forums/997-foru...-replaced.html
Long story short, the dealer addressed my concerns. I did have tires that didn't pass the tread depth though.
FYI, the CPO worksheet has been through several revisions, some revisions mention tire age, some don't. In my case, the dealer tech completely missed the tread depth.
#32
o/p - check the front tires too. If dated, replace those too.
Four new tires? Is a fantastic experience.
Perhaps keep one old front and one old rear as a spare.
You never need one, if you have one!
#33
For OP: I agree with the follow-up posts that you should check with Porsche corporate. It can't hurt and it might save you a lot of money. I'll say it is good odds it will work since those tires were so grossly out of date.
I think I shared by BMW dealer story earlier and how it was solved by appealing to corporate (and that was for a whole car... tires should be easier!), but I have just had another case of this from just a week ago. And yes this is true despite the almost too-good-to-be-true coincidence in timing.
My wife's Buick is almost out of warranty. We've taken the car in twice before with an intermittently failing FM radio (goes to static) that always resets when you restart the car. Both times they said they couldn't get it fail so they couldn't fix it. So one day I happened to be running an errand in her car and it failed, so without turning the car off I took it in and showed the failure to both the shop manager and the service agent I deal with. They acknowledged seeing it and said to bring the car back in for repairs. Then amazingly, when that repair visit was about to end, the service advisor called and said they couldn't fix it because they couldn't recreate it and couldn't tell which of two components to replace (antenna module or radio). Arghhh!!!!!
I refused pick-up of the car, asked for the number to call for an appeal to corporate, and called that number right way. After about a 20 minutes explaining this fully to the corporate rep (20 minutes due to her pulling up records on the car and calling the service advisor to confirm information while I held), she said the dealer would be calling me back right away to resolve this properly. The dealer called and said they were keeping the car, replacing the antenna module, and assigning me their best service advisor. If the antenna module replacement doesn't work, they have promised to replace the radio next and chase the problem until it is resolved regardless of whether the car is still in warranty.
So the purpose of the BMW and Buick stories are: Yes, it is normal for a service rep and dealer to say no. Appealing to corporate with a reasonable argument often works; it has both times I've resorted to it. And by the way, I've never had to raise my voice, polite but firm reasoning has always worked for me and probably works better than other possibilities.
I think you have a very good argument in your case. I bet you can win this one and saving yourself a lot of money, these tires aren't cheap!
#34
Yep, I checked and my fronts are from 08. Looks like I'll be communicating with the dealer about this. They will probably give me grief since I bought the car a year ago.
They are long distance in Philly and I'm in Raleigh. Wish me luck...
Go to know StormRune, let's hope this new coaching change will have good results...
#35
All four were from 08. Didn't bother checking with PCNA. Just got back from getting 4 new conti DWS06's installed. Ride is much much much better. And now I'm good to drive year round and hopefully get 30-40K miles out of these.
#36
30K... I couldn't get 15K out of a set of rears. And that's before I started tracking the car. You must do lot's of highway driving with that kind of milage.
#38
They are all season tires with something like 600 wear rating. Did it on purpose because with N rated summer tires I got 10k out of rear tires and 20 out of front. At 30k miles per year I was spending tons on tires. So it's all season non N rated tires for me.
On my 996 I had the alignment on the rear set up more straight so the I inside didn't wear out. Gonna watch these tires and see if I should do the same on the 997.
And nope - no track time. Strictly daily driver/commuter.
#39
So theoretically speaking would there be a legal remedy if the dealer refused to replace the fronts that date back to 08 and they missed it during the CPO inspection by using a dated form that did not specify age as the criteria? Or would it be prudent to escalate to PCNA and let them weigh in?
#40
No. The CPO paper work says minimum tread depth only. Then if it says tires were replaced must be with N rated tires that comply with the technical bulletin. So technically they don't have to. You can call PCNA and try if you want. Let me know how it turns out.
#41
I don't see how aged tires (beyond 6 years) can pass CPO, given Porsche's public position that it's unsafe and to not drive on them "under any circumstances" as published/written in the owners manual.
#42
gopirates: It is always best to exhaust possibilities like checking with PCNA first.
#43
#44
You need to re-read (or read for the first time it appears) the snippet of the CPO paperwork I included back in post 18. All of the tires must be the same age along with a few other conditions beyond tread depth.
Then is says if the tires are replaced must meet the TSB requirements, which is where the 6 year term is referenced.
So as long as all tires the same age they pass?
I hope that makes sense, but that it "technically" the way it reads.
Also, if you read it carefully, to be CPO, the tires don't have to be N rated unless they replace them.
#45
Guys...
I'm not questioning what is stated on the CPO checklist....rather simply pointing out that the dealership is certifying and/or may be selling a car with aged tires that according to PCNA, are unsafe and should not be driven on (if greater that 6 years old). If it were me, I would point this out to the dealership...and/or PCNA.
