Well ... This sucks
Well ... This sucks
Clutching in to crawl for traffic and heard a *pop*, clutch went to floor, and that was all she wrote.
Car is running fine, but no clutch. Pool of brake fluid under the car as it sits.
Must be something with the clutch slave, but what? I just replaced it!
I'm getting too old for this ...
IDOT is pretty good about sticking around til the truck gets to you.
This is the 3rd time I've broken down on I55 during rush hour, but I didn't think the third would be in a 911!
Found the problem: Leaking clutch line union.
The rubber line to the slave cylinder popped out of its joint with the hard plastic line that runs to the front of the car.
Apparently there was a TSB that was issued regarding this problem. The solution: replace part number 999.230.541.10 , "Threaded Joint"
Cost: $120
Cost: $120
Does a dealer have any obligation when something is out of warranty and there is a TSB?
I wish they published this stuff so we can take care of it before this kind of trouble.
Peace
Bruce in Philly
Peace
Bruce in Philly
Received 5,388 Likes
TSBs use to be well documented and organized by Loren on Renntech.org. Not sure if it still is.
Kev! Crap. Sorry to hear about this. At least it wasn't the clutch or flywheel like we talked about. Did you already order the part and are you DIYing?
How did you find out about the TSB?
Hey LexVan. Where do you/would you go for indie trans and engine work around Chicago?
What really grinds my gears (no pun intended), is that there are supposed to be only 20k miles on this clutch. I have no idea how the previous owner drove the car, but it's pretty frustrating.
I've heard that these Sachs clutches seem to fail pretty regularly. My fathers Z3M needs a new clutch at 29,000 miles.
