Jump Start Issue
Jump Start Issue
My Honda had a dead battery today, so I connected the 911 to jump start and it didn't work. Have jump started many cars previously without issue, got the little sparks when I finally made the connection and even heard the idle change a bit with the load. Lights in Honda came on when the cables were connected but the car didn't make any noise at all.
A jump start battery was brought out and started the Honda without any issue. The Honda does have a AGM battery if that makes a difference.
Any thoughts?
Any thoughts?
Poseur
So you hooked it up positive to positive and neg to neg? Did you rev up the Porsche a bit to aid in starting the Honda?
I never heard of an issue like this before--although I have never had to try it. When you own 8 vehicles, you ALWAYS own a battery charger/starter!
The car with the dead battery gets the negative grounded to the car frame... not to the battery.
The car doing the charging: black to black and red to red on the battery.
My understanding of this procedure is to ensure the set up drops juice into the dead battery, rather than creating a loop that it trying to equalize both batteries' levels. Electricity in the setup above goes into the dead battery.
Dead battery: red to red. black to car frame/ground
Good battery: red to red. black to black
Besides the funky wiring my only other thought is that your cables may not be thick enough. But you mentioned it started up with a different "jump battery". Do you mean a starter pack? Did it use the same cables as you used for the jump between cars?
Any thoughts?
Any thoughts?
Either that or, I dunno, space aliens?
When I am jumping a car .... isn't the battery "dead" by definition ? (ie won't turn over the engine)?
For the battery that won't start the car, is it dead if there is no voltage in the battery ? ie. check by a VoltMeter ?
Watch out... I have seen my share of blown alternator rectifiers caused by a jump start. And usually one does not notice the damage right away, as what happens is one rectifier goes bad, a waving voltage ensues, causing a rotating alternator mechanical unbalance, which eventually destroys the alternator.
Much safer to call AAA or now use one of the light/high-current-capable battery boosters.
I have a few simple rules regarding my 911S, bought new in 2009; allow as few people as possible to drive it, never say how much you paid for it and do not use it to jump-start anything other than your love of driving.
Or something similar .... Has jump starter, air compressor, alternator tester, etc, Quite a nice unit and while a bit heavy, can be put into a Pcar to help with jump starting buddies without risking your own electronics.
