best ways to avoid engine issues, Scoring and IMS on 997.1. A bit nervous
1. Yes, K&N, Napa Gold, Napa Platinum (better filtration than gold, but smaller capacity, or Mobil 1 M1-107)
2. Correct. You need an M18x1.5 with 12mm length. LN Engineering has a nice low profile one, but there are others you can find on eBay, etc. With the oil pan bring aluminum, I'd avoid using a steel plug to avoid stripping the pan threads.
3. Correct - your call on that one, but how long your clutch lasts may depend on how the previous owner drove the car. When these clutches getcworn, the pedal gets stiffer. If your pedal is stiff currently, you're not as far from a clutch job as you would like.
4. Call around and get some quotes. Transmission has to come off. I think for the IMS bearing and the clutch and labor, you're probably looking in the $2,500-$3,000 range. Also, there are 3 different IMS bearing upgrades - make sure you get the newest one called "The IMS solution" as it's the only one designed to last forever without a replacement interval. Do not get the force fed oiling version one you see advertised in the back of some car magazines.
Dang. Looked at the IMS solution website. It appears that there is only 1 certified installer in all of southern calif and even that it still over an Hr away. Is that the only people that are authorized to do this work?
Tony Callas is the co-educator along with Jake Raby for the Enthusiast and Technician M101 & M102 courses on these Porsche Engines. Couldn't have a better shop to do the upgrade for you than the guy who helps to instruct on them.
Which means? I have einstien working on the car, but costs twice as much?
Any IMS replacements in the engines with the larger bearing (late '05-'08 as a general rule) do require the engine be torn down to replace the bearing, as the bearig is larger than the hole it would have to come through.
Earlier cars that have either the single row or double row smaller diameter bearing can be changed with the engine in the car once the transmission is removed.
now he has a full engine teardown to look forward to -- or he just won't be able to sleep at night with that ticking time bomb in his garage
Former Vendor
Don't complain about having to drive an hour, I have cars here from 31 states at the present, and one just shipped from Norcal all the way to Georgia for the IMS Solution to be installed here, where I invented it. An hour is almost too close for you to appreciate the process.
