Low dust brake pads
Old Jan 8, 2016 | 12:41 PM
Rlwalker799's Avatar
Rlwalker799
8th Gear
Default Low dust brake pads
Reading past posts on this topic leaves me unclear as to a consensus on brake pad recommendations. I thought it might be time to solicit an updated opinion from the forum readers on the question of the best replacement brake pads for street use looking to maintain adequate brake performance while reducing dust and keeping noise low.
Old Jan 8, 2016 | 01:53 PM
Cbst09's Avatar
Cbst09
Hawk Ceramic pads provide great braking for street use and are very low dust. I have had good luck with them.
Old Jan 8, 2016 | 02:58 PM
StormRune's Avatar
StormRune
Another confident vote for Hawk Ceramics. Performance is fine even under autocrossing conditions with repeated heavy braking. Dusting is absolutely minimal and what little is there matches silver wheels pretty nicely. I've used them on two Porsches and a prior BMW with great results. They also come with the proper harmonic dampers (the two silver discs at the top edge) and mounting points/holes for wear sensors.
Old Jan 8, 2016 | 04:11 PM
yvesvidal's Avatar
yvesvidal
Are you talking about the Performance Ceramic Pads?
Material: Ceramic
Manufacturer Part #: HB667Z.622
Than ks
Yves
Old Jan 8, 2016 | 04:43 PM
motopix's Avatar
motopix
I have these on my 997.1
Amazon.com: Hawk Performance HB667F.622 HPS Brake Pad: Automotive Amazon.com: Hawk Performance HB667F.622 HPS Brake Pad: Automotive
I would not recommend them. Yes they have very low dusting but they also have very low initial bite and when driving in rain they are scary the way they lose initial stopping power. The description lists them as "Ferro-Carbon".
Old Jan 8, 2016 | 04:48 PM
StormRune's Avatar
StormRune
It depends upon the year, submodel, and type of rotor (iron vs ceramic) of your particular car. For my 2009 2S, the correct pads where HB667Z.622 for front and HB664Z.634 for rear. They were different for my 997.1 C4. I know the non-S models are different, I'm not sure about the C4 and C4S. I also know there are differences between 997.1 and 997.2 models.
Regrettably, many of the parts websites do not list the correct ones so you need to be careful. The safest thing to do is to use Hawk's website's search here: http://www.hawkperformance.com/parts-search. They have them correctly listed for my car, Stillen's site (for example) did not. However, Stillen had better prices than anywhere else at the time, so once I was certain I had the right part number I ordered it from them despite it being a mismatch on their page. Be sure to shop around since the price variations can be significant.
BTW, once you have the presumed correct pad shown on the Hawk website, you can press "More Details" and it will show you the shape of the pad and mounting plate (they don't show the harmonic balancers although they are there). You can use this as a double check to see if it looks like what you can see of your pads. Especially telling is the mounting point for the wear sensors and hole for the retaining bolt along the top edges. You can usually see these through the wheels on your car without removing anything.
Old Jan 8, 2016 | 05:00 PM
911searcher's Avatar
911searcher
Here is a review of someone who also doesn't think Hawk Ceramics have good stopping power.
Originally Posted by NAM VET
I really liked the non-ceramic Hawk HPS and HP pads on some of my cars. Then tried some Akebono ceramic pads several years ago on my X Sport Jag, which has always had really good brakes. I went to bed them properly, and found that from moderate speeds they simply would not completely stop the car even with two feet on the brake pedal. I promptly returned them to Tirerack, and put on my favorite Ferodo pads. I posted my experience on the reviews for the pads on the TR sale site, said they were flat out dangerous, my comment was immediately deleted.
No ceramic for me, in any of my cars.
Old Jan 8, 2016 | 05:11 PM
StormRune's Avatar
StormRune
And thus the lack of consensus begins! Of course any brake pad I'm familiar with has a low initial bite when wet. That's why you heat your breaks with a gentle squeeze occasionally when you have a suspicion the rotors have gotten wet. I feel this lack of initial bite when I go out after a thorough car wash to dry the rotors to keep them from rusting. It passes in about 3 or 4 rotations of the wheel.
Interestingly, some cars will now lightly engage the brakes automatically every so often when the windshield wipers are on. My BMW 335i did this. This is only non-driver intervention solution I know of.
Actually, if you read again he said he had non-ceramic Hawks on some prior cars but his complaint wasn't about those. He complained about the Akebono ceramic pads he installed. BTW, as motopix points out in his post, I don't think the Hawk's are fully ceramic.
Depending upon your use case, like all-out track use, I have no doubt there are better solutions in those use cases. But I'm a pretty aggressive and demanding driver... I've never had any discomfort with the Hawks except during the first second of stop time after a drenching of the rotors.
Old Jan 8, 2016 | 05:30 PM
911searcher
Interesting.
Thanks for posting.
I'm pretty sure I want the Hawk Ceramics.
Old Jan 8, 2016 | 06:10 PM
motopix's Avatar
motopix
Never had this problem on any other car whether they had track or street-oriented pads (have used Hawk, Portfield and another I can't remember at the moment, Axxis maybe).
I think my car came with some sort of Padgid(sp?) track pad they didn't have a problem with initial bite or wet performance. They were worn out though and I wanted something more street oriented (less dust, no squeal, easier on the rotors and a I assumed street-oriented wouldn't need as much heat in them to work).
The Hawks I listed are sold as street pads so I wouldn't expect needing heat in the pads to be an issue but it seems that is the case. On looking at the Hawk app chart I can see they are F rated not Z rated as others have posted.
Old Jan 8, 2016 | 06:23 PM
StormRune's Avatar
StormRune
I missed that in Motopix's post #5 above. Your link referenced the F "street" pads which are not ceramic and have little to do with what we are discussing. They are not the same as the Z "performance street" ceramic compound pads I listed. Amazon has the Z front pads listed here:
http://www.amazon.com/Hawk-Performance-HB667Z-622-Ceramic-Brake/dp/B005DK1T3E/ref=pd_sim_sbs_263_1 http://www.amazon.com/Hawk-Performance-HB667Z-622-Ceramic-Brake/dp/B005DK1T3E/ref=pd_sim_sbs_263_1
. Notice that their's is another site that lists these as not fitting a 2009 Porsche 911... but according to Hawk's site and my usage they certainly do... at least an S. The price is pretty danged good though!
Old Jan 8, 2016 | 06:36 PM
motopix's Avatar
motopix
Yeah, amazon also shows the F pad I listed as not working on a 2006S but Hawk's app a chart says it does (and I can verify).
I did butt into this thread thinking my "F" pads were ceramic vs. the Ferro-Ceramic that they are.
Carry on.
Old Jan 8, 2016 | 07:09 PM
lurchphil's Avatar
lurchphil
I have had very good luck with Yellowstuff brake pads on my 2008 and 2012 911S and also my wife's 2013 Cayenne.
Old Jan 8, 2016 | 07:59 PM
911searcher
These ?
http://www.autoanything.com/brakes/61A3072A0A0.aspx
Are they less dust producing vs. stock pads?
Old Jan 8, 2016 | 08:30 PM
stronbl's Avatar
stronbl
Just to muck up the discussion a bit more, I have switched to Cool Carbon combo street / track pads, front and rear for my street use. I find them excellent, but with a caveat. If you are using them strictly for street, you will want to do a serious bedding after install. Once bedded for street use, they are excellent in all conditions. They are also quite rotor friendly.
If you use them on the track you will find they need some heat before they get a superior bite. But once they have heated up to track temps (track braking temps), and you return to street driving they are not as effective on the street until you re-bed them (again). The dust level is minimal, which for a track use pad is very nice. If you are serious about running on the track these will work well, but you will burn through them in a couple sessions, so I'd suggested a real dedicated track pad. For the street use / spirited driving, they are quite good.
