Lowering Car
#196
I have not been back in touch with them. When I talked to the service rep he asked that I drive it for a couple of hundred miles to see if any settling takes place. I informed him that I had no trips planned until April and he had no problems waiting for that trip. He gave me his name, extension and the case number that he opened. I was planning to get in touch with him soon, time permitting, as I have put about 150 miles on the car since I spoke with him and things did settle about 1/4 inch. We shall see what he says.
#197
Are those wheels OS II Design from Wheel Dynamics? They look great. Any feedback on those would also be appreciated.
Time to update your avatar
#199
I was until recently, but replaced them with Bilstein B6 (heavy duty) because there was a rattle from my front struts. It is possible that the shocks were not completely worn and it could have simply been a loose shaft (which I heard can knock even if the damping is still good), but didn't take a chance and replaced all 4 shocks with Bilsteins.
#200
And yes, waiting on a good pic for the avatar
Next up, chin spoiler and ducky tail....still debating the "Carrera" down the side...
#201
Not in MA anymore
I've always had good luck with Eibach springs, they tend to be a bit less aggressive than H&R. (both in spring rate and drop height) That said, both brands should be designed to work with OEM shocks.
#207
Correct me if I'm wrong but doesn't installing aftermarket springs negate the height difference between PASM and non-PASM?
In other words, once you install aftermarket springs, isn't the height the same?
I can't wait for the end of winter to install my Champions with summer tires. Snow is in the forecast for Sunday, WTF?
