Hand sanitizer with rag took care of mine easily. Alcohol in the sanitizer is milder, less chance to melt the black paint off.
The **** feels plasticky now, instead of the quality rubber feel That rubber is what melted and not last this long.
996 *****: Isopropyl alcohol is the way to go and they were fine 5 min later. It's quite a mess and black for the first 30 seconds but it goes off pretty good. Look like new.
I tried a different approach to clean my gummy ***** in my 911 as I had not the right torks screwdriver to take them out.
1) Cut a small square piece of plastic, approx. 2 x 2 inches (since it´s hard to you to see the cut on the trasparent sheet I did a black one)
2) Protect the PCM panel using this plastic piece by introducing it between the **** and the panel, see pic below.
3) With some hand cleaning wipes and 96 G.L. alchool I carefully rubbed it for about 2 minutes, looking to avoid contact with the PCM panel. It worked very well, I had no damage to the **** painting and it is now ok. I saw the very small portion of the gum at the wipes at the end.
