Did the socket to remove CL wheels come with all CL cars?
I just found mine in a small, cryptic compartment in the lower left hand corner of the frunk. Had no idea I had it.
Mine did....it was outlined on page 210 of the owners manual under the section "Practical tips, Emergency Service". There is a graphic showing the cubby where the CL socket is stored in my manual.
Gotta have some kind of special wrench to use it though. Mine has a square opening where it would go And then I believe some kind of special grease is supposed to be used to remount to a precise torque number.
Yes it comes with the car. You need a 3/4” drive breaker bar and a torque wrench that will do 300+. Many threads about the “Precision Instruments” torque wrench/breaker bar set. If I had ordered a CL car from new I would have gotten 5 lug wheels.
Yup, no purpose for centerlock wheels unless you're tracking a car with timed pit stops. They're one of those things that are supposed to be cool as race technology makes it to the street, but instead are a PITA. The nubs that fit into the backside of the wheels also have a service interval and need to be periodically replaced. If you do all your service at the dealer then it doesn't matter, that is unless you ever need help on the side of the road, and then have to carry that long torque bar and multiplier with you.
not to mention when you have a flat and most shops won't touch the car. Porsche dealers also want to sell you a new tire as they "don't patch tires" Center lock wheels will probably keep me from ever taking a road trip in this car. Maybe I'm being too paranoid but I've done a few with it and have been to some desolate areas.
Good info. Thx. Not exactly a useful piece of equipment though given what else you need in order to do anything with it. Never mind that there's no spare in the car to begin with. To be honest though, I've put 40,000 miles on my GTS and the CL wheels has never given me any grief different from what 5 lug wheels would do. Without a spare, a flat in either configuration means flatbed to the dealer either way as I see it. The pump that plugs up to the cigarette lighter is useless as far as I'm concerned as is the "fixa flat" bottle that's part of the package.
I called Porsche Louisville and the service manager said bring it over. They put a permanent patch in while I waited and $50 later I was out the door.
So I wouldn't not take a trip in the car but I would be more prepared than I was. The only situation that would cause me to call a flat bed would be if the puncture was in the sidewall at which point it is not repairable with a plug. I think if I were taking a really long trip I would pack the breaker bar and torque wrench so that in the event of a flat-bed situation you could be taken to any tire shop and using your tools they could remove the wheel to install a new tire which would alleviate the need to find a Porsche dealer. At that point your only vulnerability would be tire availability but that doesn't have anything to do with CLs.
Good and valid points but isn't there also some kind of special lubricant that has to be applied whenever a CL wheel is removed and reinstalled?
So I wouldn't not take a trip in the car but I would be more prepared than I was. The only situation that would cause me to call a float bed would be if the puncture was in the sidewall at which point it is not repairable with a plug. I think if I were taking a really long trip I would pack the breaker bar and torque wrench so that in the event of a flat-bed situation you could be taken to any tire shop and using your tools they could remove the wheel to install a new tire which would alleviate the need to find a Porsche dealer. At that point your only vulnerability would be tire availability but that doesn't have anything to do with CLs.
Reasonable plan, I’d suggest you also make a copy of the procedure for removing and reinstalling a CL wheel (I think it was/is a Sticky on 6 Speed). Many local shops have no clue when it comes to CLs; doesn’t mean they can’t do, they just may not have much experience. Also, I think there is a special grease for the CL.
