Front Side Light/Markers
I'm thinking about changing my Amber side lights on my 2008 997.1 from Amber to clear. This my sound like a stupid question but, it they are changed to clear would I also change the bulb/light to Amber? Thanks I advance
Sylvania makes silver-tinted bulbs that blink amber.
But the short answer is yes. I don't think the PO changed the color of the bulb when he did the clear corner lights on my car. They aren't tinted and blink white. Haven't been pulled over for it, so I haven't changed them.
You have to have amber because of federal DOT regulations. But Ive had clear on every car since the 80s and no bodys ever said anything about it. ( I dont care about DOT laws, they never did anything for me) Most clear lenses come with a clear bulb (the ones I buy on ebay) because, if you have a clear lens, the yellow bulb shows thru, right, so you still have a yellow sidemarker. So they give you a clear bulb so now its CLEAR. You could leave it like that. The better answer is to get chrome bulbs that are yellow bulbs with chrome coating, when the are off they look clearer, not yellow. When they are on they go yellow. they emit yellow thru the chrome.
The best answer is to get LEDs. which are light colored, dont show thru the lens much. But the light when on is xenon white, blueish like the xenon headlight. Now you have more color matched lighting.
thats the goal, to have all the light bulbs emit the same color light.
If you go with the LED versions, there are at least 2-3 options out there:
1) clear lens, LED bulb blinks in amber
2) clear lens, LED bulb blinks in white
And here's is another design available (more suitable for black cars)
If you go with the normal non-LED one (OEM I believe), you can change the bulb color to whatever you want (i.e.: silver coating bulb but blinks in amber)
And also these from ECS. I think they look pretty good, as the LED segments complement those in the 997.2 front DRLs and also the tail lights. But they're a tiny bit thicker, and therefore stick out a little more.
I just installed mine, and I like them because of the added visibility they offer. They're really much brighter than the stock markers. They make a full and bright line of yellow lights, along the length of the whole marker, when indicating. Some other options are bright at the source, but fade out down the length of the markers.
I think the stock clears are a little more discreet, though. Right now, I'm going with them for function. I do like the way these look, though I don't absolutely love them.
My guess is, yes. These have individual LED "cells," and so they're a bit thicker down the whole length of the markers. The first ones you posted look great, but they only have the LED bulbs at the base of those "tubes," and so the light is not evenly distributed down the length of the marker. Again, I got these for function, so I'm okay with them, so far. They probably line up with any fender flares more nicely than the stock ones.
I have the #1 versions from the photos below bought off eBay. Clear but blink Amber. Had them for a couple years, no issues. If you do a search for "R-Kompressor" I've put up some recent pics of my car with a link to a Shutterfly album where there are more if you want to see what they look like on a GT silver car. I have smoked Dectane rears as well.
The Euro side markers are clear lens with amber bulb - Suncoast is one of many vendors selling these. Got pulled over by DPS for no front plate and also got a warning for having clear side markers - as others have said, DOT requires amber side maker. When I was pulled over my lights were on so even though lens was clear, the marker was illuminated amber - trooper said it didn't matter - had to be an amber reflector. Anyway it was a "no-fix" warning so nothing was changed.
(Sounds like you did and he didn't budge, after re-reading your post.)
The reg is for a reflector not a bulb...so even though my side markers were on showing an amber light I still got a "no reflector" warning.
