Changed the oil, 9 qts, one bar down from top?
So I changed the oil yesterday, including filter. Put in 8.5 quarts, drove it, got it hot and the gauge was at one bar above minimal. Added the last half quart, a total of 9 qts. Drove it again for 25 minutes, got oil up to 200F for a while. Checked it again, 2 bars above minimal out of 3. Drove it again the next day for 30 minutes, again the same 2 bars above minimal. Do I need 9.5 quarts? The manual says 9 quarts. Oh yeah I have the 997.1 S 3.8L.
We don't have one! HA! We only have the electronic read out. Mines a 2007 S. No dipstick, wish it did have one!
Sounds good. Just checking. I guess I was assuming that if I put in the recommended amount, it would be at the top, so recommended amount is actually one bar from the top. Good information to know, at least with my car.
That last line from the top where you can see that 1/2 segment empty is "Full". If the gauge reads completely full, that's overfull, which is bad. I add 8 quarts which gets me into the gauge range, usually have to add another 1/2 qt to get to that last line, but I do that over the next couple days in 1/4 qt. Increments using morning readings since they can move around a little bit. I believe each main section of the gauge is 0.4 quarts.
