Brake upgrade for 997.1
#46
3rd Gear
#47
I´ve purchased a 997.1 2006 C2 with 75.000kmts. Made a complete service and changed all the fluids, filters, belts, and this last sunday I´ve entered a track dayr. My main concern was the oil tempearature and pressure, and it was all going well, until I lost completely the brakes.. the pedal went to the floor after 4 laps.. very scary situation. I´ve pumped three times and the brake pedal worked.. I kept lapping a few times more to cool all the sistems. What should I do to prevent this from happening again? The climate was not so hot, around 14 centigrades at the track.
#48
Cw
#49
^Old fluid
#50
I'm getting ready to build a show car and was wondering what application do I have available. Do you still manufacture the 130MM to larger size brackets? I have a '05 C2 base with a 4L engine.
#51
https://www.ebay.co.uk/itm/293605615...sAAOSwlZNe3Mdu
#52
I saw these brackets online. Or you can buy a BBK thats made specifically for your car. The other option would be to swap our your uprights for 997.1 C2S uprights. Good luck.
https://www.ebay.co.uk/itm/293605615915?hash=item445c42292b:gxsAAOSwlZNe3Mdu
Am I right to think the rears are the same from the C2 across the 997.1 and .2?
#53
Basic Sponsor
High Temp Caliper Rebuild Kits For Brembo Calipers; Caliper Pistons
Ohio Clothing
www.ohioperformancesolutions.com
2007 C4S F77 Aerokit / 2004 E46 M3 / 2018 M3 comp
Ohio Clothing
Article_Auto (05-14-2024)
