997 Spacers
Great information. This helps quite a bit. Thanks all for the responses. I'll post some pics. I just bought the GMP Performance 7mm/15mm set. The spacers do show a smaller drilled hole that i assume is for attaching the spacer to the hub??? can anyone confirm this and what screws are used for this?
Thanks again.
Thanks again.
I would seek out hub centric front spacers. These will have a lip to set or center the wheel on when mounting...like the rear spacers will have. I tried the regular flat spacers in front and it was impossible to center the wheel and ended with a severe vibration. Sent the RSS spacers back.
Summerjack (08-24-2022)
What size spacer are your runnin on the back Rob ?
I will post pics but i just installed the GMP Spacers. 7mm and 15mm and it really makes a nice difference. Just enough to notice the wider look but not over powering. Really looks good. Thanks for the advice and support from the forum.
Don't like cross posting to other forums but here's a thread on sub-10mm hub centric spacers over at 6-speed
http://www.6speedonline.com/forums/9...c-spacers.html
+1 re: Adaptec. I dealt with the parent company/entity Motorsports Tech, and had them make a set of spacers for my C55 when fitting my OZ Superleggera IIIs purchased second hand. They can do just about anything. I wanted hub and wheel centric to eliminate any vibration issues, they easily accommodated. I think it was a 5mm spacer I ended up using.
On another note, I keep reading about 7mm/15mm spacers being the ideal/recommended set up for OE wheels, but I take it this applies to narrow body cars? My 06 C4S already has the 17mm spacers at the rear from the factory. Does this mean I should look at 32mm spacers for the rear, or just leave it as is and get spacers for the front?
My research includes mixed findings. Originally 85 pound get was popular but the I read the factory upped that to 105.
Really, the torque should also be dependent on how hard your wheels are.
Regardless, I would be surprised if loose lug bolts were the cause of the vibration. I would verify balance and centering (do the latter first with the car in the air and a run out gauge).
