Need some help diagnosing a problem
'06 C2Cab, manual transmission. Out for a Sunday drive, everything seems normal. Exiting off the interstate, shifting out of 6th, things feel weird like no engagement in the gears. Get stopped but can't get into 1st but seems to be in 3rd. I get it rolling by getting on the throttle to where I can pull over at at gas station.
Car is stuck in gear, shifter feels 'rubbery.' Ideas? Yes, I'm going to call a flat-bed.
So my diagnosis would have to be your car's shifter linkage is broken.
Do not try to nurse the car anywhere in 3rd by slipping the clutch. Just park the car and call for a flat bed tow truck.
My car's shifter was covered by a warranty, but it is not an expensive repair even if one has to pay for it out of his pocket.
A shifter is nothing compared to replacing a clutch.
Call the tow truck. This is why you should have premium auto club membership.
Unless you happened to stop the car at the mechanic you want to fix the shifter, the answer is yes, it will hurt the car, specifically the clutch, if you try to get the car to a mechanic.
Actually, once you posted I thought to myself, snap out of it you dummy. Mind is just going a 100 miles a minute waiting on the tow.
I think the shifter cable is the culprit, the shifter has zero resistance to it and it will only go up/down with no side to side.
Kudos to the tow-truck guy pretty surprised I was jovial about this situation. Will have to wait with what the verdict is from the mechanic.
I would take this opportunity to upgrade to the numeric cables. They have metal ends rather than the factory plastic bits. I'm pretty sure they can be used with the stock shifter but check with them. Or get their shifter as well and enjoy it everytime you row through the gears.
I'll call Numeric tomorrow and see what my options are.
Let me know if you are pleased witht he work at Freed, assuming that is where you ended up. I am in Chattanooga and looking fo a good Indy shop. I am also interested in a short shifter, so interested on how this turns out, thanks.
