Left Foot Braking - Pedal Position
#32
Corners and traffic can still exist on a long boring trip
Noting like a bit of left foot acceleration to mix it up a little!
#33
I broke my leg in college and the only way I could get around was to learn to drive with my left foot while my leg was in a cast. It's easy enough after a few miles.
#35
I was taught that driving an automatic with two feet was very bad form--especially if you also occasionally drive a manual transmission car where you need to use your right foot to brake.
Since you shouldn't drive with your foot resting on the brake pedal, in a panic stop, your left foot would have to come off the floor and then push the brake. Your right foot is closer and already at the right height so I don't see how left foot braking could be faster.
No, but it has occured to me before that it I hurt my right leg, I'd probably be able to drive auto fine with only my left. Since the accelerator is even more offset to the right than the brake is to the left though, and it doesn't carry the reaction time and cornering advantages of left foot braking I wouldn't personally be doing it voluntarily.
#36
I must admit it was post injury and only happened on one trip.
On reading this today I thought to test my brake light, I need to depress the pedal about 2-3mm before the light turns on. Be interested to know how others cars behave? As above, I don't rest my foot on the pedal. It tends to hover just above.
#37
Like several of the posters before me, I left foot brake during autocross (and my car is a manual). Given the very rapid and frequent swapping between braking and gas, I can't right-foot only brake and get anywhere near the level of speed control that I can with both feet. That said, I still probably end up being slower more often than not because of timing mistakes that result in the engine cutting power for what seems like an eon. Nothing as maddening as coasting for a few seconds in an autocross. Ah I wish that could be turned off.
During any other driving time, I right foot brake. I've never found it to be a problem swapping between the two. What is a bigger problem for me is swapping from the 911 (which is manual) to my other vehicles (which are automatic). Within the first 5 minutes, I will try to press the clutch in on the automatic and lock up the brakes in the process. I've got at least 3-4 gallons of dried up coffee on the dashboard and windshield.
