External Door Handle Removal - Window Microswitch
2009 C2S coupe 64K miles
Something has been bugging me for a while now. My driver side window does not drop quick enough. The mechanism does work. But... I have to pull the handle out and the window drop doesn't trigger until the last moment before the door unlatches. Therefore, the window always pops a bit against the door seal.
The passenger side works fine and triggers the window drop early enough.
It is as if the micro switch is worn somehow.
So...... how do I get in there? I have removed the interior door panel a few times now, but I think I will have to remove the inner panel to get at the handle mechanism. The part, should it need to be replaced, is 997 613 125 01. Maybe it wasn't seated properly?
Yes, I am being very picky here as the thing does work.... but it does not work as it should.
Peace
Bruce in Philly (An idle mind is the devil's workshop)
Peace
Hey Bruce,
You will have to remove the interior door panel and this includes the disconnection of two cables: (1) mechanical door latch cable, and (2) power cables to the window motor, air bag, speaker, power mirror, and door light. This is what it will look like after panel and cables have been disconnected.
Looking into the door cavity and locate the black plastic sleeve behind the door handle assembly. Press on the black plastic sleeve and slide the sleeve away from the door handle assembly to expose the threaded bolt underneath.
[Rotate pix 90 CCW]
Pull threaded bolt out until free of sleeve.
[Rotate pix 90 CCW]
Next remove the two nuts attached to the back of the door handle assembly then remove the metal door handle casing.
[Rotate pix 90 CCW]
Here are some close ups of a door handle assembly I got off of ebay. Hope this helps.
2007 C2
[Rotate pix 90 CCW]
[Rotate pix 90 CCW]
[Rotate pix 90 CCW]
2007 C2
Sheesh!!!! Thanx so much, I think this is what I have to do.
Why did you do this? What were your symptoms.
Peace
Bruce in Philly
Peace
Bruce in Philly
I didn't have to replace the door switch as you have indicated. There is a plastic rod that is attached to the door handle that connects to the door locking mechanism that had sheared off. Bought a whole door handle assembly off of eBay (as seen in the above yellow pix) as a replacement. Without this plastic rod, I was not able to manually lock/unlock my door... was relying only on my key fob for entry. If my battery had died, it would have been very difficult to unlock the door.
Here is the plastic rod after swap out...
Good luck with your swap out.
You're in for some fun :/
I did all the disassembly on my wife's black car before delivering it to the painter (it's the pink pearl one in my signature photo), and that included removal of both door handles. The worst part is trying to get the tiny snap-clip back onto the post. I don't remember if you can access the handle micro switch without taking the handle completely off, but if you can it will save you the fun with the clip.
Good luck and let us know if a new switch solves your issue.
Phoooy!!! You don't scare me!
I have access to a tow truck and dealer! Ha!
The part from Pelican is $38 so what the heck and with a few oil filters, free shipping ... ($68 from my local dealer and not available)
Part superseded by a new one: 997 613 125 02 ..... a 02 instead of the old 01
Peace
Bruce in Philly
PS...
ya, I know... I am scared but I will "crack on" as Ed says.
Peace
Bruce in Philly
PS...
Door Handle Micro Switch - Fixed!!!
2009 C2S Coupe 64K miles
MLV 250: Thanx! You da man!
I could not have done this without your pictures and advice.
So... some tips should anyone need to do this.
1 - Start with the window up
2 - I did not completely remove the inner door panel. You can see in the pics below that it will swing out enough to get your arm in there. Notice my trouble light hanging in there. I supported the panel with a milk crate. It appeared the Porsche engineers anticipated this repair move as there was extra cable to the door lock tucked under the airbag allowing me to pull it out without removing the cable. I also did not remove the inner handle cage; I let it sag in there with the door lock and then used some painter tape from the outside to hold it up.
3 - You have to remove the window motor to release the door from the mechanism. Just remove the three screws and it falls away disengaging from the window rotary thingy.
4 - Believe it or not, I did not have trouble with the screw and hood thing behind the handle. First, I got down on my right knee, and put my whole arm in there with the palm of my hand facing out, thumb down. This actually allowed me to grip the thing well. Also, you don't have to thread the screw on... the sleeve has a slot down its side and the screw pops in from the side. For some reason, this all worked rather easily for me... I do have small, slender hands. Oh, and I did this with only one nut on (the one far from the screw-hood)... just tight enough to stabilize the thing. I left the nut next to the screw-hood thing off and this gave me more room to work.
5 - I broke two of the door snaps but I had two more on hand. I keep a few on hand for just this... I have taken my door off numerous times.. install macassar trim, Focal speakers... and when you do this, they start to break.
I took a few pictures below... I wish I took a few more.
So thank you so much for your tips and advice....
Peace
Bruce in Philly
Peace
Bruce in Philly
YW glad it worked out for you!
Actually, you have helped me as well... I always wondered if my car was in an accident... since I bought it used. I thought this because I see a steel plate within the car door cavity...refer to my first picture. But the pix you have shown confirms this is not the case.
@Bruce,
I have a similar but different issue... My drivers side window lowers as soon as I pull the handle, BUT it does NOT stay down... as soon as I let the handle go, it raises up immediately making it difficult to impossible to close the door. I have to keep the handle out, and coordinate letting it go at the same time as I am closing so the window goes back up to the top in the right place.
Do you think it's the same microswitch or something else is wrong? Basically the car thinks the door is closed, so raises the window up. Passenger side is just fine...
@Bruce,
With the door closed, if you lift the handle just a bit, the window will drop. Now let the handle down without opening the door. THe window goes back up. If you open the door, and then let relaease the handle, the window goes back up when it should stay down......? If healthy, it should stay down until the door recognizes it is closed and then it will up the window.
Does anyone know where the sensor/switch is that tells the car computer that the door is closed or not?
When you open the offending door, do the car's lights come on? If not, then the switch/sensor for the door open/close is bad and it is definitely not that micro switch. I don't know where this sensor is located but it may be in the door latch.
Peace
Bruce in Philly
Bummer..... I doubt that microswitch is the problem. It sounds like your car does not know the door is open. If you open the door, do you get the light on the dash that the door is open? With the door open, start to drive. Then do the same with the other door open. Do you get the same warnings and reaction from the car?
Peace
Bruce in Philly
Peace
Bruce in Philly
I did this test, twisted the latch inside the door on the passenger side and it immediately went up and then turned it and it went down. Then on the drivers side it doesn't do anything. Window goes up regardless. So most likely it's the latch which is quite expensive.
Moderator: Based on the detailed descriptions and photographs included in this post, I think that you should consider adding it to the DIY Index. I'm sure that as our cars start to really show their age this might be a commonplace repair.
Struggling with this now and the ever present low voltage from insufficient charging daily.
