IMO it really cleans up the look and gets to Euro spec. I'm looking at LED front/rear now myself to update the look but have no advise on which ones, seems people have had good experiance with the Chinese knock off stuff from eBay.
A BT/iPod/iPhone module is a good idea if you have the BOSE MOST system. If not, a Alpine aftermarket system is better to begin with.
Originally Posted by m9bm
What mods should I do first?
2006 997.1 C2 cab.
I'm thinking clear side markers, spacers, LED turn signals?
I have the 19" lobster claw wheels.
Congrats on your new ride. I just picked up my 2006 997 Coupe about 2 months ago. I have added clear side markers as everyone has suggested as well as some new mats. Currently the car is in the shop having the following done:
Numeric Racing Shifter and Cables
H&R Springs / Alignment
Fister Mufflers
My next mod will be a set of lobsters to replace the 18 inch 5 spokes that came with the car.
Miles: 48xxx
Year: 2006
5-speed auto with no sport mode.. (don't care to row my own gears)
Options: 19" lobster claws, Bose, PCM 2.1 (stuck cd and broken cd changer..),
comfort heated seats, pcm, multifunction base wheel (ugly and thin)
Not sure what of the above is standard so I included everything.
- As you mentioned, and others have as well, go with clear side markers.
- If you want better engine sound, consider an exhaust upgrade.
- To solve your music dilemma, I would get the Dension 500 or similar. Enables BT streaming of both music and phone.
- You can replace the steering wheel by checking the options at Suncoast Parts.
- You can check out previous car in my photos, which will give you some additional options for upgrades. For example, I opted for the Sport Classic wheels that I preferred over the stock ones.
On top of the hardware mods, like the clear side marker, if you can rent/borrow a Durametric Pro you can change that clear side marker from being a running light to a turn signal so it doesn't glow orange all the time when lit and gives improved functionality as a turn signal visible from the side. I was fortunate that another forum member was kind enough to lend me theirs but I won't share his name so he won't be deluged with requests. There are places on eBay that rent them but it is still a bit pricey that way. (Warning: Be careful changing stuff if you aren't sure what it is, you can break things).
I also enabled the window up/down feature on a long button press for the key fob lock/unlock and disabled the requirement for that the brake be pressed to start the car (it is a PDK, I wouldn't do this with a manual tranny). Cheap mods if you can borrow a cable somewhere.
