Removal of front signals
Trying to remove my front signal lights on my 2007 carrera s with aerokit. The guide mentions a "card" that comes with the tool kit or owners manual that i dont have. What is special about this card? Is there any way to remove them without it?
Are you sure you don't have the card. It's should be in the trunk behind the lower panel where the tow hook is.
The card should be smooth without raised letters or numbers on it. I put two expired AAA cards together to get enough rigidity. The hotel card key mentioned earlier also seems like a good choice. My OEM lights released very easily - the LED replacements are a much tighter fit and you'll wreck the edge of the card by the time you've gotten them to pop loose. The card goes into a V-shaped slot on then side of the light and pushing it in brings in the side of the V that's has engaged with the bumper opening to hold the light in place.
