Fister Exhaust Install
#31
This is the ratchet that made those upper muffler flange nuts come off in seconds.
![Name: ForumRunner_20150226_093942.png
Size: 665.5 KB](https://rennlist.com/forums/attachments/997-forum/914764d1424972392-fister-exhaust-install-forumrunner_20150226_093942.png)
![Name: ForumRunner_20150226_094002.png
Size: 666.0 KB](https://rennlist.com/forums/attachments/997-forum/914769d1424972412-fister-exhaust-install-forumrunner_20150226_094002.png)
#32
Very nice tip there.
I bought a 13mm ratchet wrench for the 3 nuts on the back of the bracket. Rather than snaking an extension through the header - I can get to it from the wheel well.
#33
Completed the install.
It should be MANDATORY that you take the back wheels off. Just do one at a time. MANDATORY. What took me nearly 2 hours (getting to the 3 nuts on the back of the muffler bracket) without removing the wheels took me roughly 10 minutes with the wheel off.
Installed the mufflers and put the rear bumperback on in under an hour.
Some may note - and trying to help for future reference. If you remove the bumper and the tail lights - when you go to plug the lights back in you will (at least I did) get an error on the dash telling you to check your lights... even though they were working I was still getting the message. I turned my headlights on and the code went away. It's gone now.
That said - I now understand what was meant by "this is how the car is supposed to sound."
Barely noticable in "around town" driving - maybe a hint of something more but that's it. At RPM it sounds fantastic.
#34
I have some 2.25" OD exhaust pipe laying around and I was thinking I could perform the Gundo Hack on the stock exhaust on my car this weekend ...
Unfortunately, it seems that my father has commandeered the family shop's 2-post (at my parents' house ...) to change the clutch on his '02 Z3M. Is it much easier on a lift, or can I put the car on jack-stands and experience similar levels of frustration trying to get the exhaust off?
#35
Sounds like you've got some nice options for working on your car. Kudos!
I pulled mine with jack stands at the same time I did my 40K service. But mine is a Gen 2 while yours is a Gen 1. I know there are some differences.
The larger pipe might be nice, but may be more of a hassle to fabricate onto the mufflers.
#36
Beautiful A80 Supra, Wayne!
I cut my automotive teeth on early 90s Japanese performance cars.
I've had my DSM since I was a high school sophomore, and I've turned every single nut and bolt on the car.
What size do you recommend for the Gundo exhaust crossover tube? I have random lengths of various-diameter exhaust tubing from some exhaust projects/repairs to family cars in the past, so hopefully I won't have to buy a length of pipe.
#37
Oops ... I was looking (unsuccessfully) for a picture of my Fisters with Platinum ceramic coating for you. Seems I deleted it from my phone. Didn't realize the Supra picture got loaded. That is it leaving the property to make room for the .2 C4S.
This isn't the right Forum for this, but with the 6 Speed it was a great car to drive once you got past the windshield shifting right and left relative to the fenders in the twisties!
#38
You can see the exhaust needs to make two right angle turns to bypass the muffler. So at low speed (minimal back pressure) most of the exhaust takes its normal path.
I like what I've got. I use mine as a DD and for long trips with my wife. But when I do get onto the West Marin back roads I do wish it was louder.
I suspect a larger pipe would allow more bypass (you will definitely affect scavenging) and a bit more volume. I know some have done this. I haven't heard one of these.
You have the FSI mods as well (I think) and this could affect what you want to do. If I were you. I'd call Jake before I did anything. He may recommend some intake mods to maintain balance.
The best 911, outside of some GT3s, that I have heard belongs to Comanche_699. It is an absolute trip driving near him! His is a Gen 1 like yours. You may want to contact him before you make changes as well.
Good luck, and keep everyone updated on what you do.
PS: I will have my car up this weekend for a tire inspection. I could measure the bypass pipe at that time. Let me know if you would like that.
![Name: ForumRunner_20150227_170155.png
Size: 624.2 KB](https://rennlist.com/forums/attachments/997-forum/915029d1425085324-fister-exhaust-install-forumrunner_20150227_170155.png)
#39
I think the bypass is 2". The larger the pipe the more sound will come through.
Yes - you can drop the cans using just a jack / jackstand. You can leave the car on the ground to get the rear bumper off if you're going to go that route. I couldn't imagine leaving it on... its too easy to remove to justify working in a crapmed space... I contend it would take longer to remove the muffler with it on than without.
#40
FWIW, I just measured my Fisters. The bypass pipe is 1.75" O.D. The muffler pipes themselves are 2.25+.
This is a .2 C4S. YMMV.
#41
OK, so I realize I'm going to be that guy. Sorry. Haven't heard of this before. Is this a muffler delete? I have a 997.2 also, what have you noticed from the install? How does it sound compared to stock?
#42
No - its not a delete at all. Its a bypass from one pipe to another. Under low exhaust pressure - it sounds "about" the same... noticable but not obrtusive. Under higher pressures - above 4K the sound is fantastic.
This mod accomplishes what the PSE does - only without the on/off switch.
The sound is intoxicating.
#43
Refer to the picture in my earlier response. You can see the extra pipe that has been added.
#44
The 2.25" OD pipe did seem too big. I wasn't able to Gundo hack my exhaust this weekend (two of my friends had their 30th birthday parties this weekend), but at least I can get a proper bypass pipe for the hack.
Or I could just delete the mufflers altogether and run a muffler bypass pipe ...
![evilgrin](https://rennlist.com/forums/graemlins/evilgrin.gif)
#45
Newbies Hospitality Director
