replace dooor handle trim
Old May 17, 2019 | 12:28 PM
MexicoBlueTurboS's Avatar
MexicoBlueTurboS
I would definitely pay the incremental for these leather pieces. My TTS has them and it's one less thing to worry about but honestly the previous owners of my C4s must have had claws like the 'Brother from Another Planet"
Link - https://www.suncoastparts.com/produc...TDOORTRIM.html
PS - if you have a cab make sure you order for the cab window front/rear switch
Old May 17, 2019 | 12:34 PM
Petza914's Avatar
Petza914
That's one of the things I love about my interior CF trim - it's very durable and wears well. You can also adhere things to it like remotes for integrated radar/laser system, noselift kit, phone mount, etc and it comes off cleanly without any damage if you need to move it or swap it. My CF door spears look like the day I installed them.
Old May 17, 2019 | 12:50 PM
Zettinger's Avatar
Zettinger
That looks great!
I don't want to spend 600 dollar though.
My Porsche already sits at 84k miles and is my daily driver / 4 seat weekend sports car.
The car has probably an end date since at some point I will move to an 997.1 mans trans turbo.
Old Jun 4, 2019 | 02:10 PM
Zettinger's Avatar
Zettinger
Just an update.
It took me forever to sand all the interior pieces. I was pushing that job out and was lazy. btw I HATE sanding!
The second door handle trim plastic was very soft and I broke all tabs when I pulled it off. The drill out went fine but when I pulled, all tabs broke on the bottom.
I ordered both sides new from Suncoast to have matching fresh trims.
Just in black to have them painted in body color.
Old Aug 26, 2019 | 06:16 PM
Zettinger's Avatar
Zettinger
I painted the new door handle trim. new vs old.
The new ones come with extended tabs to either plastic weld them in or cut and use screws. I will have the first PPF protected before I install them
Old Jan 7, 2024 | 09:52 AM
Bxstr's Avatar
Bxstr
@Zettinger @Petza914 @Domer911 @ThunderRolls - I know this is an old thread, but I'm looking to tackle this on my 997 this spring. Can you confirm if what I'm proposing below is the best approach? I'm pretty good with interior disassembly, but I'd say I'm a below average mechanic at best. Things typically take me 2x longer than others. I'm thinking about picking up a $150 door panel off eBay to practice on before I DIY it on my 997 GT3.
1) remove door panel, I will buy all new hardware for reassembly time
2) take soldering iron and remove the old plastic rivets. Is drilling better? Or would you definitely recommend soldering iron? Any tips here? Trim should now come off.
3) take screws (of unknown size, I will buy many and see what is best) and use those to secure the door spears in place. Prior to doing this I'll need to trim the long tabs off of the spears. Do I need a Dremel for this, or will sharp metal snips work? How much do you recommend trimming or will it be obvious? Would it be wise to try the plastic weld method first and then if that doesn't work try screws? Or would everyone saw screws is best? What happens if fitment isn't perfect the first time, do I just unscrew and readjust or will there be looseness then if I have to unscrew and secure again?
I know it's a lot of questions, but I plan to buy the leather door spears when installing on my 997 so I don't want to waste a $350 part.
I plan to disconnect the battery since I'll be working near the airbag, or is that not necessary?
I definitely could pay someone to do it but I bet there's considerable cost savings DIY'ing this and I may even be a bit more careful since I'm pretty particular on these things.
Thanks!
Other thread:
https://rennlist.com/forums/997-foru...it-though.html
Old Jan 7, 2024 | 10:32 AM
Petza914's Avatar
Petza914
Have some new door panel clips on hand - probably 2 or 3 per side may break, but you don't need all new ones. Metal threaded fasteners don't need to be replaced.
Yes, use a soldering iron to melt the pins. Use a pry tool on the other side to create a little tension so you know when it's hot enough to release that pin and work your way around one at a time until the piece is free. Once it releases, keep light pressure on the ory tool so it doesn't reattach as the plastic cools.
Then use a plastic edge tool or a drill bit to clean up the holes a bit so the plastic isn't rough from the melting process. Be careful about making the holes too large as you'll need the screw head to be able to seat against it.
Then, with the new piece, fit it into the door panel and mark each plastic pin where it's flush with the door panel. You're going to cut them off just below this mark (maybe 2-3mm below) on the pin so they don't bottom out against the screw head when putting them back together - you need enough space for the screw to be able to seat against the back side of the door panel and pull the door spear in tight without the plastic pin bottoming out against the screw head.
The melting method just doesn't work as well - skip that for a first attempt and just go with the screws. I use one of those cutters that's like a scissor but holds a razor blade and cuts against a plastic cutting block so it doesn't crush the hollow plastic pin; makes a nice clean cut exactly where I want it.
Then just put the screws into the hollow tubes of the new door spear and tighten each until you get the fit perfect against the door panel. Put some thin adhesive foam insulation pieces on top of the screw heads so they don't rattle against the metal door skin.
Reassemble the door panel. Don't forget to temporarily reattach the silver inner pull handle so you can make that fit.pwrfext with the new door spear by adjusting the assembly held on by the 3 screw on the backside of the door panel. If that handle doesn't fit right, not only will it look crappy, but the window drop and rose won't work right.
Temporarily refit this silver handle BEFORE reinstalling the door panel
...so you can adjust this piece on the back of the door panel to make the silver handle fit right. Then tighten the 3 screws and remove the silver handle again so you can reinstall the panel. One of the fasteners is behind it behind that round cover.
This molded.pin needs to line up with the microswitch hole in the door spear for the window drop and rise to work. The window drops when the switch comes out and rises when the pin pushes on the switch once the door is closed.
Have fun and enjoy your upgraded door panels.
Old Jan 7, 2024 | 11:18 AM
Bxstr's Avatar
Bxstr
@Petza914 thanks so much for all of the detail. This is incredibly helpful to me.
Old Oct 16, 2024 | 02:31 AM
LloydStC's Avatar
LloydStC
I am in the process of removing the window switch bezel (or surround) to repaint it but I am having trouble removing the door pivot lever to gain access to the 9th and final plastic mushroom. How do you remove the pivot lever without breaking the pin at the bottom of the lever that goes through the two openings called dual pivot points (by Pelican)? I have tried to pull it out after removing the three screws but I don’t want apply too much force and break the pin (new pivot lever) or worse, breaking the dual pivot points where the pin goes. My latest thought is push the pin up and out using a right angle pick to get leverage. Any thoughts?
Old Oct 16, 2024 | 05:55 AM
Petza914's Avatar
Petza914
Take a plastic trim tool and gently pry up on the pivot lever while keeping it straight with the bottom holes so it slides up and out. When reinstalling, put a little silicone grease on the plastic pin making it easier the next time.
Old Oct 16, 2024 | 10:46 AM
LloydStC's Avatar
LloydStC
Thank you-I'll try it that way.
