fabspeed
Old Jun 24, 2014 | 01:23 PM
  #31
mk3boy's Avatar
mk3boy
current status
File Type: jpg
File Type: jpg
Old Jun 24, 2014 | 01:44 PM
  #32
Petza914's Avatar
Petza914
Thanks. The RUF bi-plane wing is usually fixed in the up position, but I thought it looked a little too "boy racer" when it was parked so I didi a project where I converted it to be active aero like the upper wing on the Twin Turbos. Now it's more understated when parked and below 77 MPH but lifts automatically for the additional downforce at higher speeds. Here are 2 pics - one with the wing up (older smoke taillights) and one with it layed down with the newer Dectane taillights.
Originally Posted by mk3boy
thanks. that is a pretty nice exhaust on there. Love the bumper and wing
File Type: jpg
File Type: jpg
Old Jun 24, 2014 | 02:42 PM
  #33
mk3boy's Avatar
mk3boy
looks really good
Old Jun 25, 2014 | 12:34 PM
  #34
mk3boy's Avatar
mk3boy
was suposed to ship monday but of course its late.... shipping today I am told. Painful to deal with them
Old Jun 25, 2014 | 12:39 PM
  #35
Johnny DB's Avatar
Johnny DB
Sorry to hear about the problems your are having.
Are you running PCCBs?
Old Jun 25, 2014 | 01:19 PM
  #36
mk3boy's Avatar
mk3boy
yup pccb
File Type: jpg
Old Jun 27, 2014 | 10:38 PM
  #37
mk3boy's Avatar
mk3boy
received it finaly... parts look good
File Type: jpg
File Type: jpg
Old Jul 2, 2014 | 10:13 AM
  #38
StormRune's Avatar
StormRune
Originally Posted by PhilD
I hear this a lot and there is clearly is some reason to think this could be the case. However, I have monitored intake and ambient temps with both stock and Fabspeed intakes and once you are moving at any speed there is no difference in intake temps. The massive volume of air being sucked through the engine compartment is happening so fast that there is no heating of the air going on in the engine compartment. Now at idle and slow speeds there is a difference, although not as much as you may think, between 15-25°F, but at those speeds it makes zero difference to performance anyway.
I just ran across some interesting reading on this subject in the official Technics book I recently received... see the attached shot of the section talking about those inserts at the front of the air box being there to allow sound to escape but to "avoid the intake of warm air...". I'm thinking that PhilD's observation of this not mattering at speed and only affecting the intake charge at slow/stopped speeds is correct (maybe affecting off-the-line performance?), but I just thought it was interesting to see Porsche directly mentioning that they address this issue with that polyamide material in the sound inserts.
File Type: jpg
Old Jul 3, 2014 | 09:28 AM
  #39
mk3boy's Avatar
mk3boy
good read !!
here is install pics...
Wish tips were a bit higher
Old Jul 3, 2014 | 09:29 AM
  #40
mk3boy's Avatar
mk3boy
pics
File Type: jpg
File Type: jpg
File Type: jpg
Old Jul 3, 2014 | 09:34 AM
  #41
Petza914's Avatar
Petza914
I don't see the pics, but depending on how much higher you're trying to get the tips, changing to RSS's semi-solid motor mounts will lift then about 1/4" at the bumper since they don't sag under the weight of the engine like the OEM hydraulic (rubber) ones do. Will also make the car drive and shift better as it keeps the mass of the engine from shifting around under load.
good read !!
Old Jul 3, 2014 | 10:54 AM
  #42
mk3boy's Avatar
mk3boy
good tip thanks will do
Old Aug 25, 2014 | 09:28 AM
  #43
mk3boy's Avatar
mk3boy
pics
Old Aug 25, 2014 | 09:48 AM
  #44
mk3boy's Avatar
mk3boy
ddd
Old Aug 25, 2014 | 11:18 AM
  #45
Petza914's Avatar
Petza914
Default RSS Motor Mounts
mk3boy, did you ever go to the RSS motor mounts to lift the exhaust tips? If so, what did you think of them?
