Show me your 997 with non-Porsche wheels
#1696
2011 Carrera
19X9 ET43
19X12 ET48 (ET53 + 5mm Spacer)
More Photos & Details: 911obsessed Build Thread
19X9 ET43
#1697
2011 Carrera
19X9 ET43
19X9 ET43
#1698
Maybe just lower it an inch only will visually look a lot better and still make it over speed bumps without any issues if you drive carefully over it. Again sick wheels!!!
atamez (07-11-2024)
#1701
Basic Sponsor
Our 2005 Carrera S on HRE 540R's 👍
Porsche & Euro OEM+ Retrofits/Braking/Custom Wheels and Interior
Bloomfield, CT USA
www.EurozoneTuning.com
Email | FB | Instagram | Direct Message
Bloomfield, CT USA
#1702
#1703
I think GT silver is just as pretty but in a different way as it has black in it so looks a little sportier where the platinum looks a little dmdore luxurious or refined.
Hard to go wrong with any of the Porsche silvers or greys - platinum, GT, Meteor, Seal, Arctic, Atlas, etc...
#1704
I just went with a set of LMs. I know they are common here but they just suit the car so well.
i installed a B12 pro kit (Eibach springs + Bilstein B8s), unfortunately no meaningful drop, but the car drives so well now and I’m trying to not care because my wife drives the car and it’s a backup daily driver. I have a 991.2 GT3 and E30 M3 that are plenty low and stiff already. Maybe I’ll swap in H&R springs that I have sitting on a shelf.
sorry, my car photo game is weak.
The following 5 users liked this post by F1 Kevin M:
atamez (07-22-2024),
Graufuchs (07-24-2024),
myw (07-24-2024),
Sylverlee (07-21-2024),
TerrestrialFlyte (07-21-2024)
#1705
Hi Guys,
looking for a advice on wheel fitment, i have 997 C2S (narrow body) and i`m looking at HRE 890R wheels:
Fronts 8.5J 46ET R20
Rears 11J 63ET R20
(i know 19" would look/feel better, but this deal is way too sweet to say no )
I`m 95% sure they will fit, but need some acknowledgement from you guys!
Edited:
P.s if you could help out new 997.1 owner with tyre size advice on these wheels (if they fit) that would be awesome!
Car is lowered on coilovers.
Thank you!
Rears 11J 63ET R20
Edited:
Thank you!
#1706
Hi Guys,
Rears 11J 63ET R20
Rears 11J 63ET R20
woozylv (07-24-2024)
#1707
is your car lowered?
I think the fronts will be very close to pushign beyond the fender by 1-2mm
the rears u have almost a cm until it hits the fender.
Hi Guys,
Rears 11J 63ET R20
Edited:
Thank you!
Rears 11J 63ET R20
Edited:
Thank you!
#1708
Basic Sponsor
Hi Guys,
Rears 11J 63ET R20
Edited:
Thank you!
Rears 11J 63ET R20
Edited:
Thank you!
- Brandon
APEX Wheels - expert@apexwheels.com
Website - Blog - Instagram - Porsche Fitment Guides
#1709
FRONT: 20x9 ET:49 - 245/30/ZR Michelin PS4S
REAR: 20x11.5 ET 66 - 305/25/ZR Michelin PS4S (15mm spacer)
Just as a reference. Fronts I would run as is...rears I would run a 12-15mm spacer.
@Apex Wheels is spot on.
#1710
That front wheel is 2mm inboard of the 20x9"ET50 we have sold to a few 997s before, worst case scenario is you will need to move your front strut top mounts inboard on the factory slotted mounting holes to get a few more mm's of clearance. The rear should be a non-issue, you may even end up throwing a spacer on it after you get tires mounted to have it match the front fitment. Something like 235/30-20 and 305/25-20 is likely the tire sizes you want to keep them from being too tall. A 245/35-20 front tire will be far too tall and will hit the fender liners while turning.
- Brandon
- Brandon
