Installed Hawk Ceramic Brake Pads on a 997.2
#196
Yeah that's my thinking. If they were very low in dust I could see the benefit, but they're not.
Considering Ferodo DS2500 as my next pad. Seems like a decent compromise between streetability and track performance.
#197
Update on Hawk Ceramic Pads for a 2009 Base C2
Sent: Saturday, November 24, 2018 10:29 AM
Subject: Hawk Performance Performance Ceramic Brake Pad-Yellow
Hawk,
I have seen that many people on Rennlist have said that the parts noted for their car do not fit when they receive them. I want you to double check the correct part numbers. I need front and rear pads for the following car:
2009 Porsche 911 Base Model Carrera Coupe or sometimes called a C2. I do not have an "S" or composite rotors etc.
VIN-WP0AA29909SXXXXXX
Please let me know the correct part number for your Yellow Ceramic brakes for both the front and rear.
Brian
REPLY FROM HAWK
Here are links to the correct pads for your car:
Front:
http://www.hawkpadsdirect.com/Hawk-P...b719z.668f.htm
Rear:
http://www.hawkpadsdirect.com/Hawk-P...b651z.624r.htm
These are a guaranteed fitment on your car.
Thanks and let me know if you need anything else or want to get them ordered.
Gary
HPD
1.800.918.3804
Hawk,
Brian
REPLY FROM HAWK
Front:
Rear:
Gary
HPD
1.800.918.3804
#198
So I installed Zimmerman rotors on all 4 corners (OEM) and Hawk Ceramic pads on my base 997.2. Here are the part numbers:
Front-HB719z.668
Rear-HB651z.724
I can confirm those part numbers for a base 997.2 work. Note that all rotors are 28mm new and not 34/28 like the S cars. Enjoy.
Front-HB719z.668
Rear-HB651z.724
#199
Front-HB719z.668
Rear-HB651z.724
Front-HB719z.668
Rear-HB651z.724
Why did not you install the Hawk HPS?
What is more suitable for original brake rotors?
Whose company is Porsche's original brake pads?
Is the Hawk ceramic (yellow) suitable for Rotors original brake?
#200
QUOTE=f911;15777153]Hi
Recommendations of those on this forum that have run both HPS & Ceramics. Most prefer Ceramics.
Original Porsche rotors are cross drilled Zimmerman rotors. If tracking heavily get slotted rotors and not cross drilled rotors.
Textar
These pads work great with the Zimmerman rotors for street and occasional tracking.
Thanks[/QUOTE]
Textar
Thanks[/QUOTE]
#201
Textar
Textar
