DIY - 997.2 change brake pads
FWIW- I dont like to use the crescent wrench directly on the piston b/c it may compress unevenly or nicked the metal part. Instead I just use a piece of metal in between to protect the piston and to compress it nice and even. Probably overkill, but got that advice from a rally mechanic.
larrysb (01-26-2020)
quick note here you need to unbolt the brake line carrier as well when you do this so you dont risk damaging the solid lines that go to the caliper. just did mine for the first time last week
Yep base model you have to remove the caliper to change pads. On the S brakes caliper stays on and you just pull the pin holding the pads to the caliper.
On the GT3 front caliper can stay on but rear caliper has to come off to change pads. Not eh 991 cars calipers have to come off to change pads.
I had read that the bolts need to be changed every time as well. Where would be the best place for one to get new bolts?
Doing my own pads for two cars and the occasional friend's car, I am not sure that tool is worth it to me. A couple small pieces of wood and a large screwdriver does it for me. I guess if I was a track rat, then maybe.
Nice tool though.
Peace
Bruce in Philly
Nice tool though.
Peace
Bruce in Philly
Stick a wood paint stirrer (free at Home Depot) under the pistons and place the screwdriver on that. Place a rag between the rotor and lever point of the screwdriver. Then both pistons retract at the same rate/time (or all three if a 6 pot caliper).
Yes, thread revival!
Just a quick question, what would be the safest way to separate the caliper from its mounting point. It is obviously rather hard to separate and I don't want to shake the car too much in case it falls off the jacks.
Rubber mallet would work, slowly?
[QUOTE=318touring;14713042]Yes, thread revival!
Rubber mallet would work, slowly?[/QUOTE
it should just come off. The rotor might need a whack with a hammer, however.
