DIY - 997.2 change brake pads
1. Take off two caliper bolts using T55 torx bit (pic 1)
2. Pull out the brake sensors (pic 2)
3. Take off old brake pads
4. Push the piston back (pic 3)
5. Insert new brake pads (pic 4)
6. Insert brake sensors
7. Tighten two caliper bolts to 63 ft lbs
Done
(NOTE: 997.2 caliper is different from 997.1)
Done
ohmyggg (07-30-2021)
Four pictures are worth a thousand dollars at the dealership.
On my 944 Turbo, the pads were the same size front and back, I seem to remember.
Also no torx needed. Pliers only on the star, pinch pad spring clip. Maybe a flat head screw driver to push the pistons back.
Nice cardboard on the back of the nicely painter Brembo trick
those caliper bolts need to be replaced, not reused, correct?
thanks for posting this. I didnt realize the 997.2 had the bar across the top that requires the caliper to be removed till I read this. 997.1 didnt have it and break job was 1 step quicker
good job. IIRC the calipers on the 997.2 S and GT3 do not have the cross bar and hence do not to be removed. It must be different on the BASE model???
thanks for your DIY
thanks for your DIY
On the GT3 front caliper can stay on but rear caliper has to come off to change pads. Not eh 991 cars calipers have to come off to change pads.
