eibach springs install
#61
Dubbin,
I wish i could afford coilovers, they really look much better because you can dial the rear a bit lower than the front. With the h&r the rear still remains higher than the front. Certainly does not help with front lip clearance, youve got the drop and offset set up perfectly
#62
#63
Dubbin, I wish i could afford coilovers, they really look much better because you can dial the rear a bit lower than the front. With the h&r the rear still remains higher than the front. Certainly does not help with front lip clearance, youve got the drop and offset set up perfectly
Mark
A few bonus pictures since I just got my ramp blockers for the lift and I can get the DD tucked under there
#64
I agree regarding the rake. I actually loves how the car rode when I had done just the rear and stock front (went for a short drive)
I had ton of clearance up front and the ride was confortable. Now with the front installed, it's a lot stiffer ride. I feel a lot more of the bumps etc. With PASM on it's actually teeth rattling now but I can't complain because the lack of body roll with PASM off is so worth it. The car handles like a proper sports car.
#65
I agree regarding the rake. I actually loves how the car rode when I had done just the rear and stock front (went for a short drive) I had ton of clearance up front and the ride was confortable. Now with the front installed, it's a lot stiffer ride. I feel a lot more of the bumps etc. With PASM on it's actually teeth rattling now but I can't complain because the lack of body roll with PASM off is so worth it. The car handles like a proper sports car.
Mark
#67
Do it yourself. It's not that hard, specially with the DYI on these forums.
#68
rising this thread from the dead:
Can someone confirm that these sockets will work on a 997.2 GTS w/ PASM to remove front and rear strut nuts?
Looks like they will based on the discussion here but just want the thumbs up for PoM.
21mm and 19mm Shock Strut Tools (2) Two Open Sockets
http://amzn.com/B018PWY0LO
#70
Thread revival to post pictures of my cut sockets. Had my engine builder mill out nice cuts on a pair of impact sockets. Should still be quite strong.
Also purchased some aluminum flat stock and 5mm bolts to fabricate up my own top mount washer retaining tool. Will post up photos later.
#71
good job filing those edges. and be careful if you use an impact to remove the top nut. one two many turns and you'll cut that PASM wire.
#72
I wish I could take credit, my engine builder filed the edges of his own volition, but he knew that there would be wiring in there. I'm gonna try with hand tools first in any event. Hopefully my homemade tool can work nicely, but I'm not going to start fabricating that until I have the first strut out.
#73
Started on my car this evening (06 C4S). Thought I was all prepared and knew the steps, but then found that the front strut removal process is different than the 2WD cars.
I ended up removing almost the entire front suspension. I had anticipated finishing up the fronts this evening and then attack the rears tomorrow evening, but I only got through the right front corner, and even then I need to find torque specs for all the suspension arms, and torque bolts down again But on the plus side, there wasn't any fear of buggering up the front fender! The whole strut and upright just came down in one piece.
I also fabricated my own washer retaining tool. Quite rudimentary, and it wasn't strong enough to keep everything steady so I could remove the top nut with my 3/8 ratchet, so I loosened the nut with a few blips of my impact and did the rest by hand, with the tool keeping the shaft from spinning.
