Need intake manifold vacuum line routing explanation
Hi all,
I'm trying to figure out where the intake vacuum lines go for my 2008 3.8L motor. There are some diagrams out there, but not clear to me where the lines are actually getting vacuum from. *see intake assembly pic. There is a T fitting with vacuum lines connected, that is NOT shown in the diagram, that's where I'm having trouble.
I don't clearly see any outlet on the secondary air pump either. If someone can explain what that thing does, maybe I could logically figure this out. Kinda stumped here. *See pictures attached of my secondary air pump.
I understand that the vacuum assisted valve works off the two solenoid actuators, but where is the vacuum being drawn from????
