Diy third rad install 997.2 using 997.1 set
Old 03-19-2014 | 08:20 AM
slicky rick's Avatar
slicky rick
The installation seems a success. Traffic stop and go oil temp steady at 90 and water temperature steady at 80. Easily a 5 to 10 deg improvement. What i noticed most is that the needle for oil temp seemed to be steady at that level wheareas before it would fluctuate slightly when stopped and moving.
Pinkawa (08-25-2019)
Old 03-19-2014 | 01:23 PM
PhilD's Avatar
PhilD
That was my experience too, seems to flatten out the temp. It will still get to 225°F with one hard run, but overall seems a little lower and more stable.
I'd ignore the water temp gauge as it is a glorified idiot light and does not accurately reflect the coolant temp.
Old 03-19-2014 | 08:45 PM
user 72902's Avatar
user 72902
GoPoint BT1's about $120 and will provide accurate H2O temps as well as other info. There is a module that plugs into the OBDII port and then it connects via blue tooth to a smartphone or tablet. http://gopointtech.com/products/
Nice to read CEL codes on the fly too.
Old 03-31-2016 | 05:33 PM
myw's Avatar
myw
thread bump
slick rick - a huge THANK YOU for this!
Old 03-31-2016 | 08:24 PM
slicky rick
Your welcome myw, I suppose you gunned for a set and fit it on your 997.2 already. Ha we got one over Porsche.
Old 03-31-2016 | 08:43 PM
lurchphil's Avatar
lurchphil
I just ordered the 997.1 kit and the air intake for my 997.2 from SunsetPorscheParts.com. $139.80 for the air intake, (997-575-141-070) and the radiator kit, (99704410005) @ $173.22. Genuine Porsche Coolant @ $32.03. BTW, they have the Mobilube PTX @ $28.23. (SunCoast charges $39.00 per liter.)
I installed the kit on my 2008 997.1 and found it pretty easy to do. With the excellent DYI provided by Slicky Rick, I am eager to get to work on the installation! It will also give me a chance to clean the radiators.
Old 04-01-2016 | 09:46 PM
myw's Avatar
myw
mine is actually 997.1 but i did the 997.2 conversion a year ago.... after which i always would wonder what to do re 3rd rad kit if it ever came up.
thanks to you i know its just the exact same radiator with different fitment side ducting into the larger 997.2 radiator shrouds. and just a little rubber-macgyvering will solve the issue ... i will order a kit shortly.
thank you again!
Quick Reply: Diy third rad install 997.2 using 997.1 set
