Tire Rotation
Old 04-01-2016 | 10:36 AM
tomc66's Avatar
tomc66
Default Tire Rotation
Todays project is to rotate the tires on my 911 4S. I use the X pattern to rotate the tires.
Old 04-01-2016 | 10:41 AM
yvesvidal's Avatar
yvesvidal
April's fools!!!!
Yves
Old 04-01-2016 | 10:44 AM
nk215's Avatar
nk215
never mind. I just realized the date
Old 04-01-2016 | 10:49 AM
golfnutintib's Avatar
golfnutintib
arf arf arf arf
Old 04-01-2016 | 11:02 AM
Philster's Avatar
Philster
I use the spare and do the 5-tire rotation.
Old 04-01-2016 | 11:24 AM
OKB's Avatar
OKB
do you rotate the wheels too, or just the tires?
Old 04-01-2016 | 11:26 AM
McDonn3ll's Avatar
McDonn3ll
8th Gear
Hahaha
Old 04-01-2016 | 11:56 AM
BIG smoke's Avatar
BIG smoke
Longer bolts if your rotating the rim and wheel on the same rotor. Be mindful of your new offset.
Old 04-01-2016 | 01:38 PM
rjshar's Avatar
rjshar
I just use negative spacers to get my offsets correct. Also, since it's AWD, I find my 4S handles much better with 305's up front.
Old 04-01-2016 | 01:54 PM
docdrs's Avatar
docdrs
Is it ok to rotate my 911 with my wifes Cayenne's?
Old 04-01-2016 | 02:43 PM
awrryan's Avatar
awrryan
Winter is Over, has everyone changed the air in there tires?
Old 04-01-2016 | 08:43 PM
cvtbenhogan's Avatar
cvtbenhogan
Makes sense rotate on a 4s as its AWD. I might think differently tomorrow.
Old 04-01-2016 | 10:53 PM
OKB's Avatar
OKB
wouldnt it be all the same if you just rotate the air in the tires? Then you could leave the tires where they are at.
Quick Reply: Tire Rotation
