Battery/Generator warning light on
along with a slight rise in water and oil temp, some smoke, some coolant loss and as I pulled into a gas station, the power steering seemed to be giving up too. All this within a 2-3 minute span. On a flatbed to the dealer as I speak. Broken belt?
I have done nothing to this car in 32,000 miles except change tires and oil. Just in the past 30 days I've replaced the driver's side door handle, the frunk release button in the door sill and now this. Additionally, the PCM has been acting up and is getting worse.
For those shopping for extended warranties, the "Continuous Customer Care" policy (CCC) issued by Toyota Financials has been very painless so far. I've ran up close to $2,000 in the past two months (about 70% of what I paid for it) and there's been no discussions about coverage. Best I can tell it's identical to Fidelity's Platinum plan except I have zero deductible instead of $100 with Fidelity and the policy itself was $1,000 less than Fidelity. Recommended by my service advisor who said they're easier to work with than Fidelity.
I have no current or previous affiliation with Toyota Financials other than being a customer. Just pointing out that there are good options to Fidelity which clearly is the default choice around here.
