TQ spec for front caliper to "A" arm bolts, front??
Doing a pad replacement on the Charimans 997.2.
If you know that torque spec for the 2 X front caliper to suspenson arm fixing bolts, I'd be grateful if you post them up.
I think they are M12 X 1.5 X ~ 100mm.
60 - 65 ft/lb????
Craig
60 - 65 ft/lb????
Craig
the bolts holding the caliper to the wheel carrier are spec'd at 63ftlb. but i and a few others (incl shops) i know, back that down a couple lbs to ~60 due to the possible "known issue" of stripped threads.
Thanks for the tip.
and now here's one from me.
If you choose to replace the wear sensor wire assemblies, take note that they are NOT the same lenght.
sigh
ask me how I know..................
oh well, only took 3 minutes to swap side-to-side.
Craig
sigh
Craig
Not on a 997.2. And yes, 63ft/lb is the torque spec, but for new bolts. They are torque to yield, "supposed" to be replaced everytime they are removed, hence backing off slightly torque wise due to them being pre stretched from prior torque sequence. Reusing is ok as long as you don't go crazy, but since you are asking, should be fine.
