Replacing battery--question
Old Jun 13, 2013 | 11:32 AM
Iceter's Avatar
Iceter
Default Replacing battery--question
Since the 997.2 is such a computer-intensive car, are there any special steps that need to be taken when replacing a battery?
If it's just a case of removing the old, installing the new and driving a few miles for the computer to reset then I will be doing this job this afternoon.
I just don't want to do (or not do) something and wind up having to take the car to the dealer to pay through the nose to have something re-set or re-calibrated.
Thanks in advance,
James
Old Jun 13, 2013 | 11:54 AM
chris.hanle's Avatar
chris.hanle
I have asked a similar question here. I was told there was no special things to do. But expect the computer to give you codes but, as you mentioned after a drive they will go away. I do believe the "settings" are not power sensitive. I have heard tale that while removing battery accidentally unplugged or dislodged stuff (easliy fixed, but annoying trying to diagnose).
Old Jun 13, 2013 | 12:06 PM
Luxter's Avatar
Luxter
I know for sure that there is a procedure to follow after replacing battery in 997.1.
It is relatively basic and well outlined in shop manual and has to do with resetting alarm, power windows, etc.
Don't have it with me at the moment, will try and find it later unless others will chime in.
Marc? He is always a great source of info.
Cheers,
=LL=
Old Jun 13, 2013 | 12:31 PM
JW911's Avatar
JW911
If you want to avoid all this there is a simple "kit" available from auto parts stores. It consists of a 9 volt battery and a little wire that connects the 9v battery to your cigarette lighter. I got one at Autozone for about $5. This prevents the electronics from going without power and nothing needs to be reset. Well worth the $5 investment.
Given that the above solution works, I would also expect that connecting a trickle charger, if you have one, would serve the same purpose.
Old Jun 13, 2013 | 12:44 PM
DGrayling's Avatar
DGrayling
If you use the 9 volt battery kit or trickle charger, I would cover the positive battery connector with tape so it does not touch ground while you are replacing the battery.
Old Jun 13, 2013 | 01:16 PM
jhbrennan's Avatar
jhbrennan
Thanks in advance,
James
Take out old, put in new - pretty straight forward. You'll get a PSM error on first start but that goes away after driving about 10 feet. You have to reset windows (procedure is in owner's manual - look in the index under "battery change"). I've done this multiple times - didn't even lose preset radio stations and the clock still had the correct time.
Old Jun 13, 2013 | 01:23 PM
wc11's Avatar
wc11
You need nothing special.
Pretty much any appropriate sized battery will do.
The car draws no more than any other.
Just take out the old, put in the new. Be sure to hook up the vent tube.
Old Jun 13, 2013 | 02:27 PM
Iceter's Avatar
Iceter
All great info, thanks guys.
Old Jun 13, 2013 | 02:39 PM
Edgy01's Avatar
Edgy01
Poseur
Veteran: Army
Veteran: Air Force
It's easier than you think. I step into the bottom of my trunk so that I don't have to bend with all that weight in my hands. Drive it a few miles and all those things will reset themselves. Just watch your polarity!
Old Jun 13, 2013 | 05:16 PM
Mbiondo's Avatar
Mbiondo
And be sure to immediately take her out of the garage and drive her fast-- really, really fast-- so as to remind her what is her purpose in this life!
Old Jun 13, 2013 | 05:35 PM
fskof's Avatar
fskof
Like everone here says, Its very easy to do. Nothing special. After you replace the battery you will get the PSM error (drive the car about 10 Ft and it will go away) and you will have to reset the windows (open the window completely then close it completely and it is set)
Old Jun 13, 2013 | 05:39 PM
fskof's Avatar
fskof
Yes you MUST do this otherwise your car will think its a mini van
Old Jun 13, 2013 | 06:48 PM
jhbrennan's Avatar
jhbrennan
See post #6.
Also, here is the correct procedure for resetting the windows.:
Storing end position of the windows
1. Close the windows with the rocker switch once.
2. Press the rocker switch upwards again to store the end position of the windows in the control unit.
Old Jun 13, 2013 | 07:51 PM
alexb76's Avatar
alexb76
Buy the Audi OEM battery, half the price, exact same OEM and fit.
Old Jun 13, 2013 | 07:58 PM
CBR786's Avatar
CBR786
You are aware that you need to leave ignition on engine not running when you disconnect battery otherwise the car alarm will sound as it has a battery back up and it will assume an attack is happening unless the ignition Is on. Also leave windows down or door ajar incase the door locks decide to lock when connecting new battery as you will still need to leave ignition on I think. I know this is the case with 996 I am sure would be the same for 997 but ask OPC I am sure they will divulge that info.
